1Back to top Go down   Un-identified drain hose / tube Empty Un-identified drain hose / tube Wed Oct 11, 2017 10:09 am
WINGLESS
WINGLESS
Hi all,
'85 K100RS
I have just completed my first clutch spline lube successfully ( without removing exhaust system).
During initial strip down I noticed a 7mm o/d hard plastic tube going down thro' the rear of the gearbox casting into the region of the swinging arm. This was not connected to anything at the top end.
I can only guess that this has been a vent for an older style "wet" battery.
Can anyone confirm or offer an alternative suggestion.
thanks again folks
Ian
2Back to top Go down   Un-identified drain hose / tube Empty Re: Un-identified drain hose / tube Wed Oct 11, 2017 10:59 am
ERasberg
ERasberg
Could it be a vent tube for the gas tank ?
3Back to top Go down   Un-identified drain hose / tube Empty Re: Un-identified drain hose / tube Wed Oct 11, 2017 11:15 am
Yes, if it's going through a hole in the left rear top of the transmission then it's an old obsolete battery vent/drain hose.
4Back to top Go down   Un-identified drain hose / tube Empty Re: Un-identified drain hose / tube Wed Oct 11, 2017 12:05 pm
+1 on battery drain hose.  Not necessary when using a maintenance-free AGM battery.
