1 Fuel tank leaking Tue Sep 12, 2017 6:05 am
DaleRT
Hi, Fuel tank leaking fuel. Been parked for a couple of weeks.
Around/ under the rear of the tank is wet with fuel [not pooling].
Removed tank and fuel [6lt] no signs of corrosion inside or outside of the tank.
Removed fuel sender unit to replace 'O' ring seal and noticed this on the electrical imput -
Could fuel leak out of here, those pin holes and can it be fixed ? Cheers Dale
