1 Turn signal woes Mon May 08, 2017 6:05 pm
Woodie
Hi all. New to the brick world and wanting some help. In the late winter I bought an 85 K100RT. I had driven two hours to get it and it was pouring rain while I was checking it out. The bike was started and then we loaded it up and I got on my way as fast as I could. The one thing I did not check were the turn signals. I would have bought the bike whether they worked or not.
I have absolutely no signal light action whatsoever, using either left or right or the hazard switches. I replaced the fuse, cleaned the contacts under the tank and have even tried a different right hand turn signal switch. Is the final candidate in the process of elimination the starter? The bike starts very easily and the starter does not seem to be showing any issues.
Thanks, Andrew
Thanks, Andrew
