1Back to top Go down   Speedometer weirdness! Empty Speedometer weirdness! Fri Sep 01, 2017 11:53 am
Brickboy
Brickboy
Hi all,
My new toy, a lovely K1, has a speedo funny. No speedo at all until it warms up. Then a lazy and erratic reading, frequently vacillating up to actual speed, rarely making it over 40mph though, and often returning to zero for a rest. Sometimes rising as the bike slows, but never exceeding actual (as estimated by me) speed.
Poor connection somewhere, I'm assuming. Would anyone be able to point me in the likely direction?
Many thanks,
Simon
2Back to top Go down   Speedometer weirdness! Empty Re: Speedometer weirdness! Fri Sep 01, 2017 12:13 pm
kioolt
kioolt
Follow the wire from the speed sensor on the rear drive up to the connector.  You probably have a bad connection there.  A spray of contact cleaner may help.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
3Back to top Go down   Speedometer weirdness! Empty Re: Speedometer weirdness! Fri Sep 01, 2017 12:51 pm
I agree that the most likely culprit is the speedo sensor or its connector.
More common in earlier Ks but there are also connections in the cluster that can become erratic:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/flakyspeedo/flakyspeedo.htm
4Back to top Go down   Speedometer weirdness! Empty Re: Speedometer weirdness! Tue Sep 05, 2017 7:04 am
KiwiK100
KiwiK100
Is the speedo affected in the same way as it is on the K1200 bricks? In this case a dirty armature in the starter motor prevents a solid earth connection and many of the K1200 components - indicators, lights, speedo - earth through the starter motor. Other symptoms like indicators that won't stay on while riding, or headlights that flicker at certain revs are other indicators that the starter motor armature is dirty however I don't know if the 100/1100's are affected the same way. Until someone tells me...
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD Crying or Very sad
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD Crying or Very sad
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD Crying or Very sad
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
5Back to top Go down   Speedometer weirdness! Empty Re: Speedometer weirdness! Tue Sep 05, 2017 9:49 am
AFAIK it is the load shed relay only that earths through the starter all the other components have conventional earth paths.
Many of those components get power through the load shed relay.
