1Back to top Go down   Indicator weirdness part 2 Empty Indicator weirdness part 2 Sat Oct 08, 2016 4:14 pm
TheJoker
TheJoker
Hoping someone can help I'm having a weird problem with my right indicators, they are making a really weird audible tone you can see from the video below.
(On the left they are flashing fast but this has been sorted due to the below comment)
If the video doesn't work below please let me know.
My Bike List past to present so far;
Lexmoto (first bike ever to ride) , CB125 TDC 86 , CG125 89 , GN125 97 , ER5 96 , K100 RS 84
84/01 K100rs 0013627
2Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sat Oct 08, 2016 4:35 pm
1156 for turn signals - 21W.  Very common bulb, should be at your local parts store.
3Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sat Oct 08, 2016 4:40 pm
TheJoker
TheJoker
duck wrote:1156 for turn signals - 21W.  Very common bulb, should be at your local parts store.
Thank you any idea what's happening with the right hand side though ? The indicators aren't coming on at all on that side and I'm getting that weird audible tone.
4Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sat Oct 08, 2016 5:21 pm
Could be a bad wire.
Check continuity from the bottom of the flasher relay connector to the turn signal sockets - blue/black is the right side output.
Does the right indicator in the cluster work or not?
I can't see your video - tells me it is private,
5Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sat Oct 08, 2016 5:24 pm
TheJoker
TheJoker
duck wrote:Could be a bad wire.
I've edited the video, should be public now so you should be able to see it. The right indicator doesn't work at all just get the audible tone.
6Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sat Oct 08, 2016 5:32 pm
I can see/hear it now.
The sound comes from the relay, right?
Test the continuity from the relay to the sockets. Also check that blue/black wire output to see if it is grounded. (It shouldn't be.)
7Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sat Oct 08, 2016 5:38 pm
TheJoker
TheJoker
duck wrote:I can see/hear it now.
Yes it does come from the relay, I'll check the wire tomorrow in the day light. Thank you for replying.
8Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sat Oct 08, 2016 8:25 pm
Duck's right - relay's probably kerfooked. I've got one that does that and no, don't ask me why I haven't thrown it away!
9Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sat Oct 08, 2016 9:06 pm
TheJoker
TheJoker
Dai wrote:Duck's right - relay's probably kerfooked. I've got one that does that and no, don't ask me why I haven't thrown it away!
I've just replaced the relay with one that is known to be working seen on another bike.
10Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sat Oct 08, 2016 11:52 pm
Rickmeister
Rickmeister
Just a thought...have you had any grief with starting / starter motor. I had a similar problem with the blinkers going haywire, bike not starting with the starter motor. Removed the starter motor, cleaned it and replaced the brushes and all was good!
11Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sun Oct 09, 2016 8:29 am
TheJoker
TheJoker
Found the problem thank you it was a loose wire to the the rear indicator. Continuity test helped me when I was checking the other wires. Should have really done that to begin with.
12Back to top Go down   Indicator weirdness part 2 Empty I had that exact same problem.. Sun Oct 09, 2016 5:19 pm
Bumblebee
Bumblebee
Trouble traced to a shorted bulb.  Actually any short would do that.
- John
http://Bugsmashers.org/phpbb
13Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sun Oct 09, 2016 7:55 pm
TheJoker
TheJoker
Bumblebee wrote:Trouble traced to a shorted bulb.  Actually any short would do that.
- John
Yup now onto my other problems, only got a few things left before I get it through mot.
Headlight setting up - rewire sidelight and other wiring
Forks- replace seals
The only other concern at the moment isn't electrical though, it's down to the coolant bottle. I've recently refilled the coolant and it is completely empty. So obviously the overfill isn't working correctly. Unless I'm being stupid right now.
Needs the other horn bracket sorting but it doesn't look that bad in my opinion with the new indicators. A lot different to before it was stolen nothing is tightened up as I'm still working through it. No garage so has to be done at the side of the road.
Indicator weirdness part 2 LapPqBu
14Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sun Oct 09, 2016 8:26 pm
TheJoker wrote: The only other concern at the moment isn't electrical though, it's down to the coolant bottle. I've recently refilled the coolant and it is completely empty. So obviously the overfill isn't working correctly.
And you have checked that the radiator is topped up, and all air removed from the cooling system?
15Back to top Go down   Indicator weirdness part 2 Empty Re: Indicator weirdness part 2 Sun Oct 09, 2016 8:38 pm
TheJoker
TheJoker
Yes all air is removed from the system that I'm aware and the radiator is topped up. It's just the black coolant bottle is empty at the moment. Obviously something isn't right. I refilled it before it was sold to the friend; so its worth having a check see if he has messed with anything.
16Back to top Go down   Indicator weirdness part 2 Empty Coolant bottle can crack Sun Oct 09, 2016 10:53 pm
Bumblebee
Bumblebee
Another issue I had was that the coolant bottle had developed a small a crack over time, it was not too big and the coolant would leak out very slowly.
Check the coolant bottle carefully.  In my case the crack was at a seam on the side of the plastic bottle.
Also, make sure the hose is good...it leaked in my case too, only a few weeks later.
My K-100RT is 28 years old, it's always been inside unless I am using it, and been well looked after, plastic parts and rubber bits (like the radiator hose) have failed over time.
YMMV.
- John
