ok thanks for the replies, done some other things which I will post in the relevant sections (thermostat stuck open) now electrics, not my strong point, like many others if the light at the top of the traffic lights is on its red, on the bottom it's green, was going for my powder monkey certificate years ago but thought it might be dangerous red and green flags and all. So to recap, rear brake switch had worn the little button off so a new switch from RS industries, small mod to make it fit but for $6 delivered worth it.
New switch fitted no brake light, low power to the switch, less than 11v.
Cleaned earth from Battery to engine, it has 2 earth wires running to it, is the any other ground/earth wires, have read there is 1 under the tank, mine is 91 16v is mine different?
Removed and opened the bmu relay, can't see anything wrong but don't know what I am looking for and if I did know can I see it.
So hook the bmu back up, now I have no tail light at all no brake lights and if I turn the indicators on they don't work but the clock disappears,
I am thinking the bmu, help, Gary
