Number of posts : 12058
I would hazard a guess that the 2nd gear is not meshing properly. It probably has bent the selector which in turn stops the gears meshing far enough and then the gear will jump out occasionally then slowly get worse. It is usually a series of missed shifts that causes it to start happening. You could get the dogs repaired by a machine shop but I would be looking for a good used set.
