1 Low RPM Low Power Jerky Acceleration Tue Aug 11, 2020 9:26 pm
Ohnij
Looks like a number of folks here have had similar issues as mine.
Problem:
The Bike starts right up, but idles around/slightly above 1000 RPM. Also to note, my battery warning light comes on at startup, but turns immediately off at the first rev and never comes back on(Anyone Else?). The main problem I'm facing is that I have very jerky, delayed, poor acceleration below about 2500 RPM. The problem seems to go away once the bike has been running for about 15 minutes or so.
Possible Diagnosis(Untested):
Tracking potential root causes from other posts ive read.
The first couple of things im gonna try are the cheaper options aka charging the battery, fuel filter, and spark plugs. I'm gonna have a guy test the coils this friday. (Fingers crossed cause them thangs are about $200 each) I'll keep you guys updated
Problem:
- Low Battery
- Bad Ignition Coils
- Bad/Dirty Fuel Injectors
- Replace Spark Plugs
- Replace Fuel Filter
- Hall Effect Sensor (No Idea what this is but flippin $200 to replace)
- Crankcase Breather hose (Please god $15 fix)
