Number of posts : 12058
Second to first in a downshift is the first place you will notice dry splines on a K. As for the GPI switch just let it dry out in the sun and clean it with alcohol then pick away all the crumbling hard rubber and I then use a polyurethane glue like "SIKAFLEX" and coat it with that let it cure for a few days and no more problems. If you need to get it apart again a razor will cut the glue. Once you have the old rubber off you can pull them apart to clean it but it's got lots of tiny springs that hide in corners.
