ffbikersa
ffbikersa
Hello everybody,
A buddy who runs a BMW workshop approached me today with an unusual question: someone who owns a 1991 K 1100 LT complained to him how he's "missing a 6th gear" in his gearbox. I often had the same feeling while riding my K 1100 RS. The LT in question has the final drive unit marked with 31/11 - and my buddy asked me to check if final drive units with other ratios have been installed on the Paralever models. I had a look at the Motorworks site and found out that 32/11 too was installed on K 1100 LT as well, while 33/12 was foreseen for K1.
Has someone tried installing a 32/11 (or 33/12) unit instead of 31/11 - and if yes, what were the results? Is it possible to obtain just the different gear wheels and replace them, instead of the whole unit? Of course this question may be answered by K 100 and K 75 owners too, as there too final drive units with different ratios have been installed.
Missing 6th gear on a K 1100 / installing different final drive unit? Final_10
Cheers,
Tarik
2Back to top Go down   Missing 6th gear on a K 1100 / installing different final drive unit? Empty gear changes Tue Sep 12, 2017 7:52 pm
Can always put a larger profile tyre or rim on if top speed is an issue....ie K1100RS is 18inch
Cheaper easier and can even borrow to trila from a friend.
KKlompy Missing 6th gear on a K 1100 / installing different final drive unit? 2854237993
Missing 6th gear on a K 1100 / installing different final drive unit? Au-log10
I have a 2.62 ratio from a K1200RS/GT which to be quite honest does not prevent needing a 6th gear. There is one gear set that is used which is 2.53 from an R1200c.  I also have a 2.75 ratio drive sitting somewhere in my shed that I believe came from a later model K1100 (not sure if an RS or LT) it is a direct fit but the others will need to be swapped into a K1100 paralever housing.
This chart will help
Missing 6th gear on a K 1100 / installing different final drive unit? Image212
Don't worry about a sixth gear - just let it rev! The engine loves it and starts to wake up at 5,000RPM.
GB777
GB777
I have installed the R1200C gears into the final drive housing on my K1100RS and previously into the final drive housing on my K100 and it works great. It trims off about 500 rpm in top gear at 100kph. There is another thread on this forum which has covered this topic.
Gary
'94 K1100RS Mystic Red
•Dyno Tuned to deliver 115 bhp. •Audiovox CCS-100 Vacuum Cruise Control. •Fuel Plus Version 3.1 Trip Computer. •R1200c Final Drive Gears (32/13 or 2.54). •Ohlins rear shocky. •K100 complete Aluminium Radiator fitted. •Davies Craig Thermo Switch fitted to Cooling Fan with manual over-ride. •Fuel Cap drilled and tapped to provide mounting points for accessories, including mini Tank Bag & Apple CarPlay Screen •HID Hi-Lo Headlight and every other incandescent bulb on bike replaced with LED's. •Bulb monitoring warning light no longer needed so it's now used to indicate when Side Stand is down. •LED (Halo) Front Park Light (BMW Car style).
6Back to top Go down   Missing 6th gear on a K 1100 / installing different final drive unit? Empty 6th Gear Mon Jan 01, 2018 5:55 pm
Pegasus
Pegasus
G'day Garry,
long time no see.
I still have my 93 K1100RS and I'm still out at Ipswich.
cheers,
Andrew
To add to this thread, is it necessary to swap the inners or can one simply swap final drive [and driveshaft?] ?
You have to swap the innards because there is no shock mount, no speedo sensor or caliper mount.
