2 Re: Air box removal question Thu Jun 09, 2016 8:41 am
4V - yes, 2V - no. On the 2-valves there's an airflow meter in the top of the box which is an integral part of the fueling system. The most you can really do with that is hang the AFM directly off the plenum chamber inlet and fit it with a K&N or similar.
3 Re: Air box removal question Thu Jun 09, 2016 8:55 am
andyldean
OK thanks for that wondereday why I couldn't find any info on Web.
4 Re: Air box removal question Thu Jun 09, 2016 5:33 pm
Motorbike Mike
Fit early 4 valve ECU,sub loom and sensors-it's easy if you can get the parts,
I did it with a 2 valve K100 track bike to simplify the intake system and get rid of the air flow meter. I've now changed to a 16v motor so all's well again.
5 Re: Air box removal question Fri Jun 10, 2016 6:27 am
Hmmm - that's got my attention. Did you run into any problems at all?
6 Re: Air box removal question Fri Jun 10, 2016 6:38 am
A question on this. Does the 16 valve use/require the 4 hole injectors?
1971 Yamaha 125 YAS-1
7 Re: Air box removal question Fri Jun 10, 2016 7:14 am
No92KK 84WW Olaf wrote:A question on this. Does the 16 valve use/require the 4 hole injectors?
8 Re: Air box removal question Fri Jun 10, 2016 10:27 am
Motorbike Mike
No problems at all with fitment. The 2v ran well but not quite perfect according to the dyno readout. It made 89bhp at the rear wheel but it was a tuned motor.Dai wrote:Hmmm - that's got my attention. Did you run into any problems at all?
Similar topics
