1Back to top Go down   Air box removal question Empty Air box removal question Thu Jun 09, 2016 7:14 am
andyldean
andyldean
Interested in the possibility of removing the air filter box.
I understand that performance could suffer but the overall look is the aim here.
Is this image below possible?
Air box removal question Images10
2Back to top Go down   Air box removal question Empty Re: Air box removal question Thu Jun 09, 2016 8:41 am
4V - yes, 2V - no. On the 2-valves there's an airflow meter in the top of the box which is an integral part of the fueling system. The most you can really do with that is hang the AFM directly off the plenum chamber inlet and fit it with a K&N or similar.
3Back to top Go down   Air box removal question Empty Re: Air box removal question Thu Jun 09, 2016 8:55 am
andyldean
andyldean
OK thanks for that wondereday why I couldn't find any info on Web.
4Back to top Go down   Air box removal question Empty Re: Air box removal question Thu Jun 09, 2016 5:33 pm
Motorbike Mike
Motorbike Mike
Fit early 4 valve ECU,sub loom and sensors-it's easy if you can get the parts,
I did it with a 2 valve K100 track bike to simplify the intake system and get rid of the air flow meter. I've now changed to a 16v motor so all's well again.
5Back to top Go down   Air box removal question Empty Re: Air box removal question Fri Jun 10, 2016 6:27 am
Hmmm - that's got my attention. Did you run into any problems at all?
6Back to top Go down   Air box removal question Empty Re: Air box removal question Fri Jun 10, 2016 6:38 am
A question on this. Does the 16 valve use/require the 4 hole injectors?
7Back to top Go down   Air box removal question Empty Re: Air box removal question Fri Jun 10, 2016 7:14 am
92KK 84WW Olaf wrote:A question on this. Does the 16 valve use/require the 4 hole injectors?
No
8Back to top Go down   Air box removal question Empty Re: Air box removal question Fri Jun 10, 2016 10:27 am
Motorbike Mike
Motorbike Mike
Dai wrote:Hmmm - that's got my attention. Did you run into any problems at all?
No problems at all with fitment. The 2v ran well but not quite perfect according to the dyno readout. It made 89bhp at the rear wheel but it was a tuned motor.
