1Back to top Go down   Bar end removal Empty Bar end removal Fri Feb 14, 2014 8:07 am
Culminator
Culminator
Hi all, I want to repaint my handlebar ends but can't seem to remove the first one. Is there a knack or is it simply a case of unscrewing the retaing screw and using a slide hammer to remove?
Mike
2Back to top Go down   Bar end removal Empty Re: Bar end removal Fri Feb 14, 2014 9:14 am
MikeP
MikeP
Model would help, some are different.
1992 K1
3Back to top Go down   Bar end removal Empty Re: Bar end removal Fri Feb 14, 2014 9:20 am
Culminator
Culminator
Oops. It's a 1992 K100RS
4Back to top Go down   Bar end removal Empty Re: Bar end removal Fri Feb 14, 2014 9:59 am
MikeP
MikeP
They should just slide off, leaving the inserts.
I'd start trying to rotate the end weight once the counter-sunk screw is out. Try introducing some releasing agent at the grip end (roll the grip back a little).
If your bike has BMW heated grips, the threaded section of the insert has a roll-pin that stops it coming out but the non-heated grip version may pull the inner tube and rubbers out with it.
This is what is under the weight:
Bar end removal K1%20BMW%20%28136%29-L
The roll pin:
Bar end removal K1%20BMW%20%28140%29-L
1992 K1
5Back to top Go down   Bar end removal Empty Re: Bar end removal Fri Feb 14, 2014 9:22 pm
kioolt
kioolt
I seem to remember a different style weight on my 91 K100LT.  I believe that it has a wedge type of arrangement.  With is you would loosen the screw but not remove it and then tap it with a hammer to drive the wedge out of the bar end weight.  I've had them off before but I really don't remember how.  I just remember that it wasn't hard.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
6Back to top Go down   Bar end removal Empty Re: Bar end removal Sun Feb 16, 2014 2:40 pm
Culminator
Culminator
All sorted now. The bar end weight was pretty fixed into the bar via a bit of surface rust. Took quite a few blows with hammer and chisel to shift it.
