1 starts but won't accelerate / rev up Fri Apr 15, 2016 10:32 am
Tony goodwin
Starts fine all else seems fine. Just won't rev up . Bought it like this . Any suggestion?
92KK 84WW Olaf wrote:Hi Tony
Don't be afraid to ask questions, we all had to start somewhere on these and sometimes the question you don't ask is the one that causes you trouble.
If bike is starting AND ticking over ok you may well have an issue with the throttle cable having come awry inside the handlebar mechanism. Clearly you are getting fuel and spark so don't go chasing in there just yet. The handlebar mechanism has a chain inside it that needs an occasional lube and if incorrectly maintained you can end up with..........no throttle. If you can see the other end above the injector rail you will see where the cable ends and there is an adjustment screw/stop where it rests at idle. You should see this lift when you turn the throttle. If it doesn't, use your finger to see if it lifts and if it does lift fire up the engine and do it again. If it revs for you then check out the handlebar mechanism.
1989 K100RT VIN 0097367 (naked) 1996 K1100RS VIN 0451808 | Fuel: 95 Octane Engine Oil: Nulon Full Synthetic 15W50 Gear Box Oil: Nulon Synthetic 75W90 |
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » starts but won't accelerate / rev up
Similar topics
