Number of posts : 12058
Arr right I misunderstood what you meant.
Try putting 12 volts and earth on the 2 terminals on the relay where the 2 pin plug is that will determine if the problem is in the relay or futher back in the start switch or the wiring. Also try pulling the clutch lever in as you start, if there is a change and it will start it means the problem is in the feed from the gauges.
The black/yellow wire also goes to terminal 4 of the ECU and terminal 6 of the ICU and the start button but does go direct to the start button so measure the resistance of that wire and check the 9 pin plug from the handlebar switch block to the harness for bad connection.
If you want a good colour circuit or manual with it then send a PM and I will send a link.
Keep going as you know just how good they are when they are working well.
