1Back to top Go down   Problem - no power to the fuel pump Empty Problem - no power to the fuel pump Tue Aug 22, 2023 6:02 pm
Rochen
Rochen
Hello everyone,
Let me give you a bit of context. Last Saturday, I went on a ride with my 1986 K100 8v motorcycle, and after about 15miles, the bike broke down on me. The symptoms were similar to fuel starvation, as if you were running out of gas.
Over the past few days, I've been testing and checking things, and here's how it went:
  • First, I checked if the spark plugs were producing a spark. I also tested each spark plug with each spark plug wire, and all possible combinations produced a spark. So, I've ruled out spark plugs, wires, and coils.
  • Second, I checked the injectors. It seemed like there was fuel coming out, but very little. I removed and cleaned both the injectors and the injector rail.
  • I also checked the air filter just in case, it was a bit dirty but nothing serious.
  • Finally, I removed the fuel pump, connected it directly to the battery terminals, and it was pumping fuel well, both with and without the fuel filter.
Upon removing everything, I noticed that there was this filter, is this the correct one?
Problem - no power to the fuel pump GUdXqZN
Then, while making sure the fuel pump was working properly, I connected it back, but there was no sign of movement. I tested it with a multimeter, and there's no current reaching it! No wonder isn't working. Do you know what could be the issue? Fuel level sender? Check the wiring?
On another note, while searching for information on the forum, I found that you can bridge fuse 6 of the pump with the positive terminal of the battery, and there should be movement. However, there's complete silence.
And one last question, I've taken a video inside the tank. It seems like there's some debris but not too bad. However, I couldn't identify the fuel level sender. Instead, I saw 2 wires that go directly from somewhere to the pump.
Thank you very much, everyone. I've attached the video.
Fuel pump function
Interior fuel tank
PS: I also checked the fuse for the pump and it's ok
Suzi Q
Suzi Q
Check all the hoses inside the tank for splits.
Check the electrical connector to the fuel tank - under the front left hand side - I think yours might be the 4 pin circular type which are prone to poor connection. If that is the case then BMW thoughtfully provided a 'spare' 4 pin plug in the relay box (which is actually an accessory connector) you can cut this off and use it to replace the original.
Yes; the connector is the most obvious problem. The connector has female pins inside it, so you can try using a very thin screwdriver to get between the outside of the pin and the wall of the connector, then twist carefully to close the gap in the pin.
Rochen
Rochen
You are the best, you are both right. It was the round connector under the tank.
I have been touching it to verify and it has already fallen, I have seen that it is very loose and I will carefully try to close the pins more so that it makes more force.
Thank you all very much since I had missed checking that connector. Finally it has gone "okay" so I have been able to review and clean several things on the bike that always comes in handy
Regards!
Rochen wrote:You are the best, you are both right. It was the round connector under the tank.
Regards!
Some time back I bought a few of those plugs from Tills.de as I have 3 running early Ks with those plugs on them. Worth buying a few sets.
