1Back to top Go down   Instrument cluster bulb fittings Empty Instrument cluster bulb fittings Sat Aug 07, 2021 8:23 am
tinyspuds
tinyspuds
Dai wrote in response to a charging light issue I have:
2. One or both copper tabs on the flexi-pcb has folder backwards rather than be poking down into the bulbholder's socket. It's dead easy to miss this when putting the bulbholder back in. What happens is
- you pull the bulbholder out and as you do so, the flexi-pcb flexes far enough so that the copper tab(s) clear the socket
- the copper tab(s) move into a position that is just slightly more than 90 degrees to the socket
- the flexi-pcb snaps back down but the copper tabs don't go back into the socket - that over-angle causes them to fold under the main flexi-pcb
- there's still enough copper exposed to make a connection with the bulbholder's contacts (most of the time)
- eventually they either stop making contact or they fracture away from the main flexi-pcb.
Seen a few like that. Actually, seen a lot like that.
As I have the cluster open I thought photos for those unfamiliar (like I was 10 minutes ago) might be helpful.
Instrument cluster bulb fittings 296a4210
Circled yellow is one of the backlight bulb fittings.
Circled red is an empty socket with the copper tabs lifted away from the socket sides when the bulb fitting was removed.
Instrument cluster bulb fittings A076cc10
This is a backlight bulb and socket. The bulb is pushfit in either orientation (unless you have LEDs in which case orientation matters.
Instrument cluster bulb fittings D366da10
Underside of the flexi strip with the copper tabs for a backlight. Easy to see how these might fold under the strip rather than descend into the socket.
2Back to top Go down   Instrument cluster bulb fittings Empty Re: Instrument cluster bulb fittings Sat Aug 07, 2021 10:22 am
mike d
You can get the same problem on the airheads.
Mike
3Back to top Go down   Instrument cluster bulb fittings Empty Re: Instrument cluster bulb fittings Fri Aug 13, 2021 2:57 pm
tinyspuds
tinyspuds
Having resolved my alternator issues I took the opportunity of an open instrument cluster to upgrade my backlights to LEDs. 3 of the 4 sockets did exactly as Dai described. Be vigilant.
4Back to top Go down   Instrument cluster bulb fittings Empty Re: Instrument cluster bulb fittings Fri Aug 13, 2021 3:36 pm
It really sucks that after you put the instrument cluster back together, install it on the bike and connect the big connector, you turn the key and one of the backlights doesn't light up. Arrrgh!!!
5Back to top Go down   Instrument cluster bulb fittings Empty Re: Instrument cluster bulb fittings Fri Aug 13, 2021 8:20 pm
tinyspuds wrote:Having resolved my alternator issues I took the opportunity of an open instrument cluster to upgrade my backlights to LEDs. 3 of the 4 sockets did exactly as Dai described. Be vigilant.
See? I told you my middle name is SmartAss. Instrument cluster bulb fittings 44271 Instrument cluster bulb fittings 44271
6Back to top Go down   Instrument cluster bulb fittings Empty Re: Instrument cluster bulb fittings Sat Aug 14, 2021 3:58 am
Point-Seven-five wrote:It really sucks that after you put the instrument cluster back together, install it on the bike and connect the big connector, you turn the key and one of the backlights doesn't light up.  Arrrgh!!!
Got a point there Very Happy
Don't put the cluster back together, first try on the bike.
Instrument cluster bulb fittings Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
