1 Trouble shooting ABS on a K1 1990 Fri Jan 22, 2016 12:04 pm
playlikewedream
Hi guys
I was suspicious recently that my ABS wasn't working so I removed faring, removed clock, found previous owner had removed ABS fault bulb, I replaced this reassembled fairing. Switched ignition on ABS light on dash flashes, ticking under tank, pressed ABS button on fairing ABS light on dash goes solid ticking under tank stops, so what next, fault light works button on fairing works.
Any help would be much appreciated.
Pat.
Pat.
K1 1990 Laguna Blue and Yellow
K1100RS 1997 Sedien Blue.
Its not about the journey or the destination, it's about the friends you make on the way.
