Chocolate
Number of posts : 757
Hey Pat!
You should do the batterie reading 2 hours or better a day after driving or charging, so the reading is more realistic.
12.54 Vol sounds like a good healthy batterie. Could have up to 12.8 - 13 Vol if super duper.
Some more info
https://en.wikipedia.org/wiki/Automotive_battery[th]Open-circuit voltage[/th][th]Approximatecharge[/th][th]Relativeacid density[/th]
[th]12 V[/th][th]6 V[/th]
12.66 V | 6.32 V | 100% | 1.265 g/cm3 |
12.35 V | 6.22 V | 75% | 1.225 g/cm3 |
12.10 V | 6.12 V | 50% | 1.190 g/cm3 |
11.95 V | 6.03 V | 25% | 1.155 g/cm3 |
11.70 V | 6.00 V | 0% | 1.120 g/cm3 |
If a batterie is faulty or OK you can normally only test under load, meaning ignition is on and the motor is of.
But the normal test should do it for you.
