1Back to top Go down   electric diagrams for K1  Empty electric diagrams for K1 Thu Jan 14, 2016 8:59 am
playlikewedream
playlikewedream
Hi guys
If anyone out there has detailed electric diagrams for a K1 I would be grateful if you could send them to me .
2Back to top Go down   electric diagrams for K1  Empty Re: electric diagrams for K1 Thu Jan 14, 2016 9:16 am
Chocolate
Chocolate
3Back to top Go down   electric diagrams for K1  Empty electric diagrams for K1 Thu Jan 14, 2016 9:40 am
playlikewedream
playlikewedream
Hi
Thank you very much for the quick response.
They are fantastic.
Cheers.
4Back to top Go down   electric diagrams for K1  Empty Re: electric diagrams for K1 Sat Jan 16, 2016 4:42 pm
playlikewedream
playlikewedream
Hi espresso
I think I have a battery on its way out. Could you tell me what the optimum reading while testing the battery should be, am getting a reading of 12.54 is this good or bad?
Pat.
5Back to top Go down   electric diagrams for K1  Empty Re: electric diagrams for K1 Sat Jan 16, 2016 5:27 pm
Chocolate
Chocolate
Hey Pat!
You should do the batterie reading 2 hours or better a day after driving or charging, so the reading is more realistic.
12.54 Vol sounds like a good healthy batterie. Could have up to 12.8 - 13 Vol if super duper.
Some more info
https://en.wikipedia.org/wiki/Automotive_battery
[th]Open-circuit voltage[/th][th]Approximatecharge[/th][th]Relativeacid density[/th][th]12 V[/th][th]6 V[/th]
12.66 V6.32 V100%1.265 g/cm3
12.35 V6.22 V75%1.225 g/cm3
12.10 V6.12 V50%1.190 g/cm3
11.95 V6.03 V25%1.155 g/cm3
11.70 V6.00 V0%1.120 g/cm3
If a batterie is faulty or OK you can normally only test under load, meaning ignition is on and the motor is of.
But the normal test should do it for you.
6Back to top Go down   electric diagrams for K1  Empty battery Sat Jan 16, 2016 6:04 pm
playlikewedream
playlikewedream
Hi Espresso
didn't test under load and was on charge at time, so will test tomorrow. New to this so learning as I go so thanks again.
Pat
7Back to top Go down   electric diagrams for K1  Empty Re: electric diagrams for K1 Sat Jan 16, 2016 6:58 pm
Chocolate
Chocolate
Just measure the batterie without load, the result will tell you enough For now.
Something to read and watch for cold winter evening :-)
https://m.youtube.com/watch?v=dB7CFqVlhtI
http://matchlessclueless.com/electrical/general/battery-voltages/
http://www.totalmotorcycle.com/maintenance/battery.htm
8Back to top Go down   electric diagrams for K1  Empty Re: electric diagrams for K1 Sat Jan 16, 2016 7:39 pm
playlikewedream
playlikewedream
Absolutely brilliant
Thanks a lot.
Pat
9Back to top Go down   electric diagrams for K1  Empty electric diagrams Mon Jan 18, 2016 6:12 pm
playlikewedream
playlikewedream
Hi Espresso
Tested battery under load and as your links suggest I have falling ampage so need new battery , ordered one yesterday so when I get it sorted will see what's next ie resetting abs from fault mode, will let you know.
Pat
