1Back to top Go down   K100 electric problem.  Empty K100 electric problem. Fri Oct 23, 2015 2:46 pm
TheJoker
TheJoker
Problem: press the starter only get a low audible click no ignition.
Back story:
Today I purchased a new loom for my crashed and stolen recovered k100. It came from a working bike for £15. Bike is not working though
What I'm getting:
I'm getting 12v at the battery.
12v at the green wire for the ignition
12v with the button to ground 86 of the starter relay.
12v at fuse1
Now when I turn the bike on I press the starter button and all I'm getting is a very low noise click. The starter motor isn't engaging at all.
Now before I take the motor off is there any other possible problem it could be?
I'm trying to rule everything out.
2Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Fri Oct 23, 2015 2:48 pm
TheJoker
TheJoker
Won't let me edit on my mobile I'm also getting 12 volts at the red wire from the ignition.
My Bike List past to present so far;
Lexmoto (first bike ever to ride) , CB125 TDC 86 , CG125 89 , GN125 97 , ER5 96 , K100 RS 84
84/01 K100rs 0013627
3Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Fri Oct 23, 2015 3:36 pm
kioolt
kioolt
Since you have a voltmeter put it on the starter motor and check for voltage.  If you've got voltage and the motor isn't running it's the problem.  Make sure your grounds are good.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
4Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Sat Oct 24, 2015 2:16 am
TheJoker
TheJoker
Thank you kioolt. That was my next port of call. I know I've got good earths already. Is there anything else you could think of?
5Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Sun Oct 25, 2015 2:41 pm
TheJoker
TheJoker
kioolt wrote:Since you have a voltmeter put it on the starter motor and check for voltage.  If you've got voltage and the motor isn't running it's the problem.  Make sure your grounds are good.
I've checked the starter motor and it's working, did the bench test on it. The grounds are fine.
I removed the fuses to check what voltage I'm getting out of them and got the following in order note only the headlight is connected;
1. 12.4
2. 0.2
3. 12.4
4. 5.4
5. 12.4
6. 12.4
7. 12.4
I'm still getting 12 volts at the battery, 12 volts at the green wire and red wire on the actual ignition. And 12 volts at 86 on the starter relay.
Really not sure where to go from here any advice Question
6Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Sun Oct 25, 2015 2:58 pm
Try to ground terminal 85 on the starter relay temporary.
If the starter then turns, the problem is in the ignition ECU or the wiring/connectors
between the starter relay an the ignition ECU.
7Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Sun Oct 25, 2015 3:02 pm
kioolt
kioolt
Have you measured the voltage on the big wires on the starter relay?  I believe they are terminals 30 and 87.  One should be 12 v all the time and the other should have 12 v when pressing the starter button if everything else is ok.
AMA,BMWRA,BMWMOA
8Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Sun Oct 25, 2015 4:23 pm
kioolt
kioolt
TheJoker wrote:Problem: press the starter only get a low audible click no ignition.
Back story:
What I'm getting:
12v at fuse1
Starting at the top of your original post.
The low audile click is most likely the starter relay but it could be something else.  By no ignition I'm assuming you really mean that the starter isn't working.  If I'm wrong please let me know.
Are you getting 12v at the battery when pressing the start button?  It's best to check the battery voltage under loaded conditions.
This statement has me a bit confused.  "12v with the button to ground 86 of the starter relay."  Do you mean you have 12 volts measuring from terminal 86 of the starter relay to ground when the button is pressed?
From the way that I am interpreting your description,  I see that the starter relay is clicking when the starter button is pressed but that the starter motor is not turning.  This is one of two things.  The starter relay or the starter itself.  You say you have tested the starter on the bench so that means it is your starter relay.  To test the starter relay measure the voltage on the two little wires when the starter button is pressed.  You should have 12v.  If you have 12 v then next check for 12v on the two big wires on the starter relay.  You should have 12 v on both big wires when the button is pressed and 12 v on only one wire when not.  If the test with the little wires passes and the test with the big wires does not then the starter relay is bad.  If both tests pass then the starter is bad regardless of your bench test.
Further information on the starter relay.  The starter relay needs 12v + from the starter button and a ground from the ignition unit to operate the starter.  Once the engine starts the ground is removed by the ignition unit.
AMA,BMWRA,BMWMOA
9Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Sun Oct 25, 2015 5:08 pm
TheJoker
TheJoker
kioolt wrote:Starting at the top of your original post.
By no ignition means that when I press the button I get nothing, no dimming of the headlight. No audible noise; nothing.
When I press the button I'm still getting 12v, I've checked another battery as well and it results in the same.
"12v with the button to ground 86 of the starter relay."     This means that someone told me to try with the power turned on so the neutral light is showing check that terminal 86 is getting 12v I checked as well with the button pressed and got the same result.
I was getting a low audible click when I turn the key to the on position and pressed the button; but now I'm not getting it when I press the starter button. I checked the starter motor on the bench using jump leads to the battery and it turned. So the starter motor is actually working.
I will check the starter relay tomorrow.
10Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Tue Nov 03, 2015 9:18 pm
Kiwi_Roy
Kiwi_Roy
Hi, I'm new here from Wild Guzzi, I must say the standard of Electrical help is very high.
I found an excellent document by Bertrand Vogel "EFI/Electronic Ignition K100 2V Troubleshooting", this should be in every-ones tool box.
Have you tried jumpering out the two large terminals of the Start Relay, that will prove out the battery, wiring and starter (make sure the bike is in Neutral first), use a heavy wire #12 or larger.
If you unplug the start relay you should see 12V across 85 - 86 of the connector with the button pushed.
If not monitor each point to ground as you push the button (with the relay in if you can)
11Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Wed Nov 04, 2015 3:59 am
TheJoker
TheJoker
Well I was having problems still so I tried jumping the starter motor (live wire straight from the battery to the starter motor) with it attached to the bike and got nothing pulled the plugs, to be honest it was one thing I know I should have checked but just didn't. Then tried jumping with the starter motor again and got the bike cranking.
Didn't get the bike started but there isn't that much fuel in the tank. So I'm thinking that it could possibly be something to do with the wire linking the starter motor to the starter button. Or something else. I'm getting another parts bike though which is of the same year as mine. Mostly intact with a running engine. So should give me something to play about with.
12Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Wed Nov 04, 2015 5:16 pm
Kiwi_Roy
Kiwi_Roy
When you jumper the starter it may not start because the Ignition module won't pick up the Fuel Injection Relay (I may be wrong, I'm new here) to start the pump and fire the injectors,
Jumpering around the Start Relay was just to prove the battery and starter motor are ok, those you can rule out now.
Bertrand Vogel's excellent document shows a simple schematic and table on page 19.
On page 16 it shows
Power comes from the battery, (thru the ign switch not shown), thru the kill switch, thru a fuse, thru the clutch switch, to the Start button, from button to the relay, If you don't have a multimeter solder a couple of wires on a small 12 Volt lamp and use that to trace the power flow, one wire connected to the chassis.
If you have a meter measure the resistance of the start relay coil, I have no idea what it should read but less than 100 Ohms is my guess.
Be sure to test your lamp before starting by connecting it across the battery
If you get as far as the start relay and you still get 12 Volts with the button pressed it could be the Ignition module is not holding pin 11 at ground, I would measure that with a volt meter.
Just reading back in the thread you said you had 12 Volts at 86 of the start relay, just to be certain can you check that at the Ignition Module pin 11 with the key on button pushed?
Last edited by Kiwi_Roy on Wed Nov 04, 2015 5:33 pm; edited 5 times in total (Reason for editing : Re- read previous post by Joker)
13Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Wed Nov 04, 2015 5:50 pm
On page 16 it shows
Bert (Crazyfrog) is our esteemed Overlord and Creator and all his work is hosted or linked in this site off the Portal page. A lot of it is in the members only section.
Re soldering wires to a 12v bulp.... Just run down to your local auto parts shop or even a $2 shop and buy a circuit tester for about $5.
K100 electric problem.  78616
 K100 electric problem.  Austra12    Fuel:  95 Octane
14Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Wed Nov 04, 2015 6:09 pm
Kaptain, I'm certainly not questioning your electrical prowess, but I was led to believe that those circuit testers are not to be used on our bikes.
An LED type is preferred?
15Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Wed Nov 04, 2015 6:22 pm
kioolt
kioolt
A circuit test like that is ok working on the starter circuits.  It's when you're working with the Hall sensors that you don't want to use that kind of tester.
AMA,BMWRA,BMWMOA
16Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Wed Nov 04, 2015 8:03 pm
Thanks for the clarification kioolt.
17Back to top Go down   K100 electric problem.  Empty Re: K100 electric problem. Wed Nov 04, 2015 8:09 pm
kioolt wrote:A circuit test like that is ok working on the starter circuits.  It's when you're working with the Hall sensors that you don't want to use that kind of tester.
Spot on Kioolt that is why I recommend to get into the habit of using an LED test light on any electrical circuit and preferably a digital multi meter.
