1 Grease fittings in center stand? Fri Sep 04, 2015 9:23 am
jkh
I have a 93 K75RT. I have a Grease fitting on the side stand - nice easy to grease then. Onvthe center stand there is only a little hole. Os this normal ør has the PO changed the center stand?
As the center stand is not retracting properly i though that i would put a Grease fitting in there. Can this be done without remowing the center stand mount?
