1Back to top Go down   Center stand bush Empty Center stand bush Mon Jun 17, 2013 3:09 am
Got the handle bars back in place today so adjusted the clutch cable. While I was there I noticed the center stand had a lot of slop in one side, the side stand side. It looks like the bush is missing, completely gone. I think it would be 5 in this diagram. It says it's a 24mm bush. Any idea what else I can jam in there to remove the slop?
Center stand bush Stand
2Back to top Go down   Center stand bush Empty mine Mon Jun 17, 2013 3:12 am
ibjman
ibjman
I had to replace my stand.......as it seems that as the bushes wear out, the eyelets they fit in in the stand also grow oblong. I was afraid if I only replaced the bushes that the stand would soon fail under the weight of the machine.
3Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 3:12 am
just note the circlip that fits on the end as well ....many times I have seen that the stand has actually bent out wards past the circlip position and obviously the clip has long gone .
perhaps a bit of brass would fit in there
im sure the bm shop would have one ..for you
4Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 4:03 am
AuntieBB
AuntieBB
Definitely something to attend to sooner rather than later.
I'd break a bolt (no. 6 in the diagram) on my centre stand about every 30 to 35,000km (probably an indication of my short stature - rocking the bike at an angle to get it off the stand).
It's a massive pain in the arse when the bolt breaks at a rest stop in the middle of a ride and you can't leave the thing sitting sideways rubbing on the tyre. It's a 15 minute job crawling around in the dirt under the bike trying to undo the other bolt while trying to avoid the hot exhaust pipe.
And then off course, you have a nasty, dirty lump of metal to ockky strap onto your bike somewhere to get it home.
ahhh... memories
Last edited by AuntieBB on Mon Jun 17, 2013 4:15 am; edited 3 times in total (Reason for editing : 3 times - 3 times! it's a dyslexic afternoon)
once upon a time: 1987 K100RT/TIC
now: 2010 R1200GS
5Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 4:06 am
I pulled it off for a closer look. It's been repaired/welded, only the spring side has a circlip, the side stand side is just a bolt into a bush. I got that bolt out. The circlip side is rusted in by the looks, I'll let it soak in WD40 overnight and hit it with heat tomorrow if it's still stuck. It's just as sloppy as the other side, was just being tensioned by the springs I think.
6Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 5:14 am
MikeP
MikeP
I've never found one with two circlips yet, apart from those where I've added a second. The circlip function is to stop the pivot from being drawn into the stand too far, thereby losing the end float. It won't stop it falling out if the screw is lost.
The pivots are meant to wear rather than the stand itself wearing.
The countersunk screws are held with blue loctite so some heat will make things easier when stripping it.
The pivots are relatively cheap.
7Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 5:25 am
Cheers Mike, they're not cheap here. Munich wants $10 each for the bush + $3.30 for the screws + $10 Postage = about 23 pound !!!
It's not urgent though and with the jack I can get it off anytime so it's it's looking like another parcel from Britain Smile
8Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 6:54 am
Blue is the weaker one isn't it ? So hit the screw itself with heat to melt it?
9Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 8:49 am
MikeP
MikeP
Robin, It is.
If you can direct the heat at the open end of the screw thread in the sub-frame, it will make it a lot easier:
Center stand bush K1%20BMW%20%28287%29-L
The loctite always seems to be down at that end:
Center stand bush K1%20BMW%20%28288%29-L
10Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 9:10 am
Cheers, I had a go earlier with a gas blowtorch and it didn't move Sad
Tomorrow is another day Smile
11Back to top Go down   Center stand bush Empty wow Mon Jun 17, 2013 2:19 pm
ibjman
ibjman
RobinW wrote:Cheers Mike, they're not cheap here. Munich wants $10 each for the bush + $3.30 for the screws + $10 Postage = about 23 pound !!!
Wow robin! the more I read about the cost of parts there "down under" (the primary source seems to me "Munich Motorcycles"?.......the more I think you guys down there need an "agent" like myself here in the USA to buy up all the used K's we can find here in the USA and after we get a bunch, pack them all in a shipping container and ship the whole lot to AU.
12Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 9:35 pm
Just to comment on the prices here
I needed a cam chain kit for the k1100 and priced one from Motobins and it cost $128 landed in my mail box.
I then just for interest checked Munich Motorcycles in Perth who had a price of $440 but Bruce said especially for me $400 (the magnamous prick). I then for a laugh rang Morgan and Wacker the Brisbane big BMW dealer who wanted a paltry $620.
These Idiots and I repeat Idiots still cant figure why we shop overseas.
We so often hear Australian businesses complaining that they are going broke because of people buying overseas but it just doesn't seem to impinge on their tiny minds that they are the problem.
I recently purchased 2 sets of tyres for the K1100 from Rockymountain Motorcycle and ATV and landed then at my local post Office for $600. The best price I could get from my local guy was $400 for 1 pair fitted (Michilin PR2).
After I got the tyres I went to the local bike shop to get them fitted and he cracked up about me buying somewhere else and said $40 each to fit them so I told him where to go and what to do when he got there and went to a local auto store that fits tyres and they did them for $13 the pair and ballanced on the dynamic ballancer. I tried to give him some business but he apparently objected to that so now he gets none and I have picked up some of his K customers.
The ironic thing is that he buys most of his BMW spares from Motobins and charges "real" BMW prices.
I will add one more to the list here.
I use a CPAP machine to help with sleep aopnea and the Machine I use is made in Sydney Australia and costs $1800 from the Resmed dealer here in Brisbane. I can buy the very same made in Sydney Australia machine from a place on Ohio for $600 plus about $70 postage. GE are now making a CPAP machine and selling it in US for under $200.
Australiab Businesses have the idea that they have some God given right to rip off the public to any extent they want to but now that the internet is here the shoe is firmly on the other foot and oh boy arent they naking a noise about it and some have gone so far as to want the government to stop the people from doing this horrible thing of having a fair go.
Rant over
I have nearly got my k1100 back together after what Saxon seems to think was a monumental explosion Center stand bush 214585
13Back to top Go down   Center stand bush Empty Re: Center stand bush Mon Jun 17, 2013 10:03 pm
I can't budge that bolt. Every time I shoot WD40 in the grease needle hole, red stuff comes out. Heat didn't help at all. I'm guessing it's rusted in. I've also completed the butchering job on the hex head that someone else started, so I'll have to drill it out. Just ordered every bit going for both the center and side stand, it's wobbly too, for about $45 delivered.
14Back to top Go down   Center stand bush Empty Re: Center stand bush Tue Jun 18, 2013 8:31 am
Did you heat the bolt until bright red or nearly white with the torch? I had the same problem as you are having and took my stand to a local muffler repair shop.  They heated the bolt nearly white hot with an oxy-acetylene torch before using an hex driver to get the bolt moving. The stand came out unscathed from this treatment but the bolt I had to replace naturally.
15Back to top Go down   Center stand bush Empty Re: Center stand bush Tue Jun 18, 2013 9:17 am
MikeP
MikeP
Another tip, once you get it really hot, dab it with an old candle and the wax will melt and flow down the threads.
16Back to top Go down   Center stand bush Empty Re: Center stand bush Tue Jun 18, 2013 9:49 am
MikeP wrote:Another tip, once you get it really hot, dab it with an old candle and the wax will melt and flow down the threads.
My bike deserves more than just an old candle, I shall use a nice new one.
17Back to top Go down   Center stand bush Empty Re: Center stand bush Tue Jun 18, 2013 10:06 am
I don't have an oxy torch, I guess i have a plumbers soldering torch, so it won't get it glowing hot, but it got the swingarm bearings out Smile
I put it back on the bike until the parts arrive next month, then I'll drill it and get an easy out into it and have another go.
I doubt wax will get into the thread, even from a new candle Smile I'm pretty sure it's solid rust in there.
It's a pity I can't get the actual stand bit off to see what's going on in there.
When the parts show up, it might be wise to soak it in some sort of penetrating fluid for a bit before attacking it.
18Back to top Go down   Center stand bush Empty Re: Center stand bush Tue Jun 18, 2013 10:33 am
Acetone and automatic transmission fluid mixed 50/50 is the best penetrating fluid you will get and its cheap to make.
19Back to top Go down   Center stand bush Empty Re: Center stand bush Tue Jun 18, 2013 10:43 am
Really ... I got a bottle of acetone and need more trany oil. Just the ticket. Cheers Rick.
20Back to top Go down   Center stand bush Empty Give it a squirt Tue Jun 18, 2013 1:15 pm
ibjman
ibjman
Give it a dose of the "mix" every day between now & then. I assume he means Acetone and ATF???
21Back to top Go down   Center stand bush Empty Re: Center stand bush Tue Jun 18, 2013 4:15 pm
walfish
walfish
When I did mine I used a small stilson wrench around the head of the screw, I know the head is narrow but it worked for me.:arrow:
Center stand bush Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
22Back to top Go down   Center stand bush Empty Re: Center stand bush Thu Jun 20, 2013 8:25 am
I did try a big set of vice grips, trust me, it's stuck Smile
23Back to top Go down   Center stand bush Empty Re: Center stand bush Thu Jun 20, 2013 10:00 am
The big problem is that 1mm of steel makes 25mm of rust and that has a habit of making things permanent.
Try peening it with a ball peen hammer all round the external part of the thread you will need to do it for quite a qhile but not too hard. This can expand the metal slightly and give you enough room to move.
You will need an anvil of some type maybe a large hammer held in the vise and a small hammer 12oz to peen it. You might need to spend 1/2 hour doing it just tap tap and go all round it many times.
24Back to top Go down   Center stand bush Empty Re: Center stand bush Thu Jun 20, 2013 10:23 am
Anvil,  heheheh, yep got one of those ...
Bit smaller than the ones in the cartoons though ... hehehhe
Center stand bush Anvil
25Back to top Go down   Center stand bush Empty Re: Center stand bush Sat Jun 22, 2013 2:25 pm
Just taken mine apart to see why there is a lean to the right. Glad that I have the impact gun. One side the bush is well worn and the other a bit worn. I think that the stand is worn too so I will wait for the new bushes and measure them then decide to ream and bush if needed.
26Back to top Go down   Center stand bush Empty Ream? Sat Jun 22, 2013 2:32 pm
ibjman
ibjman
One might use a large dose of caution before reaming out the eylets at the top of a center stand. They're pretty darn thin from the get go & you can't afford having one "part" just as you're rolling a fully loaded machine up onto the stand........If your's is worn it might be better to look around for a gently used one or weld up the missing material before reaming back to size to fit the standard new bush.
Regards, Ibj...
27Back to top Go down   Center stand bush Empty Re: Center stand bush Sat Jun 22, 2013 2:49 pm
bikerboy wrote:Just taken mine apart to see why there is a lean to the right. Glad that I have the impact gun. One side the bush is well worn and the other a bit worn. I think that the stand is worn too so I will wait for the new bushes and measure them then decide to ream and bush if needed.
i see that too on the one I can get out. There is a good 5mm worn away on one side.
28Back to top Go down   Center stand bush Empty Re: Center stand bush Sat Jun 22, 2013 4:45 pm
From my measurements the outside of the bearing on the stand is 30mm. I think the bush should be 20 to 21mm so the sidewall is 4.5 to 5mm thick. If I get a bush that is 1mm wall thickness and a H8 fit then I am sure there will be no loss of strength. I just need to get to a dealer on Tuesday and hope that they have the bits in.
For now I will fit the stand bracket back on the bike with just the side stand on it.
29Back to top Go down   Center stand bush Empty Re: Center stand bush Sat Jun 22, 2013 9:12 pm
The fiche under parts at max bmw calls it a 24mm bush.
30Back to top Go down   Center stand bush Empty Re: Center stand bush Sun Jun 23, 2013 5:39 am
RobinW wrote:The fiche under parts at max bmw calls it a 24mm bush.
The printout (also from MaxBMW) that I have in front of me reads "SLEEVE from 11/89" and it is about 20mm. Are you looking at an earlier one?
31Back to top Go down   Center stand bush Empty Re: Center stand bush Sun Jun 23, 2013 5:49 am
Mines a little older than yours Smile
05 46 52 1 454 038 SLEEVE - 24MM (from 05/84)
32Back to top Go down   Center stand bush Empty Re: Center stand bush Sun Jun 23, 2013 6:05 am
Bikerboy are you looking at a 16v side/centre stand, you said from 11/89 and that is about when the first 16v bikes appeared.
33Back to top Go down   Center stand bush Empty Re: Center stand bush Sun Jun 23, 2013 6:29 am
ungaas wrote:When I did mine I used a small stilson wrench around the head of the screw, I know the head is narrow but it worked for me.:arrow:
with the help of Mr Klompy's vise grips , mine eventually eased out, thankfully.
Not an easy task when the factory uses all of the hold tite chemicals.
but I suppose it's better than trying to dismantle your undercarriage from the rear wheel, oops!
Center stand bush 10_x_110
34Back to top Go down   Center stand bush Empty Re: Center stand bush Sun Jun 23, 2013 6:49 am
RicK G wrote:Bikerboy are you looking at a 16v side/centre stand, you said from 11/89 and that is about when the first 16v bikes appeared.
Yes Rick, mine is a 16v. It seems that they made a change but it still wears and goes wobbly!
35Back to top Go down   Center stand bush Empty Re: Center stand bush Sun Jun 23, 2013 7:25 am
I bought a second hand one (for a K1100) that's got grease nipples (snort, giggle) fitted.
Is that a factory thing? It wouldn't hurt to fit a couple to a least keep the bushings greased?
36Back to top Go down   Center stand bush Empty Re: Center stand bush Sun Jun 23, 2013 7:56 am
Mine has grease nipples on both the centre and the side stand. I would suspect that the PO did not have a grease gun or did not know that they were there.
37Back to top Go down   Center stand bush Empty Re: Center stand bush Sat Jun 29, 2013 6:22 pm
Johnser
Johnser
I've just drilled and tapped a K100 '87 centre-stand for grease nipples as per the later ones.
Looks like early sidestands could be converted with some of the bits from a later model (the longer bolt and special collar) but if you're going to go to that trouble it may just be easier to fit the whole later system.
38Back to top Go down   Center stand bush Empty Re: Center stand bush Sat Jun 29, 2013 9:31 pm
Best thing about the K1100 stand is the ease which the bike goes up. I can get mine on the centre stand while still astride the bike.
