KJustin
KJustin
I've been doing cosmetic work, converting my 85 K100RT to a cafe racer. Bike was running fine. I took off the tank and my homemade seat/tail for painting. While I had things apart I did some minor electrical cleanup. E.g. Put a disconnect plug on for tail light and rear turn signals and put an aluminum cover over the battery, moved the horn.
I had the battery on the charger, so it's topped up. Took it off for a few days. Turned the key, headlight and speedo lights came on like they should. Hit the starter button and everything went dead. Bike never turned over, no fuel pump noise. Nothing. Silence. No power anywhere except for the clock on my acewell speedo. Flipped the key a few times and got zero power anywhere, except, as noted the clock is keeping time and never cut out.
After pulling each fuse--all looked good--I took my aluminum battery cover off. Turned the key, lights came on, hit the starter and same total failure (except clock) as described above.
Then I jiggled the battery around a little. Turned the key, lights, starter, fired right up. Repeated 3 times.
I have a lithium ion battery--if it makes a difference.
Could this just be a loose or corroded battery connection that I revived by jiggling things about? Or is there something potentially more sinister I should address?
Sounds like a problem I was having, turned out to be a bad earth connection. Check the battery earth to gearbox area, undo it and give it a good clean, then the earth under the tank, has a few wires joined on. Mine turned out to be a loose battery terminal post, after I'd done all the above, of course. Look for easy problem first and good luck.
KJustin
KJustin
Thanks RT Today. A few months back I chased a starting gremlin that turned out to be a loose plug to the ICU at the headstock. Of course it was the last thing I checked. As a result, all the chasing led me to clean every connector under the tank including the main earth with deoxit.
I wouldn't be surprised if you are right about the battery to engine earth. I know that's a known problem and I did have the battery wires off when I was moving my battery about. I'll clean and torque the connections to be safe.
Any other takers on things I should check/consider?
1985 K100 Cafe Racer (formerly an RT), VIN 0051736
Possibly the ignition switch is flakey and needs disassembly/cleaning.
brickrider
brickrider
As has been noted often here on this forum, DeOxIt is your friend when dealing with such puzzles.
The LiFePO battery could be the culprit. Their chemistry is a bit different and require some consideration when starting, during warmup and also when charging. Stress like poor charging and cold weather can affect their initial cranking amps. They need to push a little current first to get going.
You said you had the bat on charge.
What charger are you using?
How long was it charging?
Which lithium battery do you have?
LiFePO4 batteries have a very low 'self dissipation rate' and don't really require additional charging unless really necessary and they're easy to overcharge. They don't like desulphination mode as they don't sulphate. also they may not trigger the float mode on a trickle charger which can remain in full charging mode till you disconnect it. That will damage a litjium battery
When stressed they can take a little time to get going/reactivate.
Sounds like there was maybe enough amps to activate the LSR solenoid coil but not enough initially to power the fuel pump and starter till it recovered.
Unlike a lead acid bat, which must be maintained above 75% charge, LiFePO4 bats can be discharged MUCH further without damage so not really necessary to keep it topped up which can damage the bat if not properly done.
Just my thoughts
 Complete electrical failure--odd experience but working now; would still like input Austra12    Fuel:  95 Octane
+1 on RBM's comment about the ignition switch.  Your symptoms sound an awful lot like what I was experiencing this spring with my bike.  That switch is a very bad design.
KJustin
KJustin
I'll need to check the ignition switch. It was replaced when I bought the bike in 1999, because the original had gone bad. I rode the bike quite a bit when I first got it (all sorts of weather, lots of rain) and then didn't ride it for about 8 years due to a combination of my father being killed in a MC accident and having little kids myself. Point being, the switch has light use, but still could have corrosion, so I'll check it.
The battery is a Scorpion SSTX-300FP. It has a button on the top to test the charge which illuminates three LED lights, or only 1 or 2 if it's not at full charge. The bike had been sitting 2.5 months so I pressed the button and only got 1 LED light. So I put a trickle charger (1 amp, I think) on for 24 hours. After that I had 3 LEDs and took the charger off. Then I let it sit for a 3-4 days. Then hit the starter and the rest of the story is above. Also, temperatures have been warm here. It was probably 95F in my garage when I tried to start the bike.
I wasn't aware of the issues noted by .75 WRT Lithium iron batteries (except that I did know the need to be warmed before cranking in cold weather) but I think I was pretty conservative in my approach to charging. Does it sound likely that I did damage?
I just put the battery issue up as another possibility. The other suggestions are also valid and should be investigated, but I have to point out that everything was seemingly working till the starter button was pressed and then the lights went out. Sounds like the LSR was doing its job but no juice getting to other components whether that was due to a poor connection or no juice from the battery??? Something doesn't seem right. Could be a combination of a couple of things maybe. Often faults don't surface till something else fails or falls below performance levels like battery voltages. Always pays to keep all connections and switches clean and functioning rather than wait till something happens imo and then its a struggle to diagnose.
Battery damaged??? Who knows? The Scorpion has a Battery Management System built-in. What will tell is the service life you get out of it. But what I understand is that you should be able to let that battery sit for months disconnected (some say even a year) without charging and it should fire the bike up no probs. It's certainly got enough CCAs. One thing's for certain, they don't like trickle charging, but with the correct charger, IF you have to use one, they should charge up very quickly. Depends on the charger and the size of the battery but anything from 30 mins to 2 or 3 hours.... but in theory you shouldn't have to.
In case you're wondering, I don't use a LiFePo. I considered it but went for a quality AGM. Similar performance but a trade-off between less $$ and the weight.
KJustin
KJustin
Thanks all. Turns out the earth to the gearbox was loose. Must have gotten better contact when I moved the battery around to get it started. Anyway, I tightened it up and starting is flawless as before. But, I'm still going to do a quick clean of the ignition switch to be safe.
Glad you found the problem Justin.  I have worked as a sailboat mechanic now for nearly 15 years.   Experience has taught me that the first thing to check when there are general electrical system problems is the condition of the main system grounds.  If they aren't clean and tight all sorts of strange, non-specific things will happen.  I hope you will remember this experience.
KJustin
KJustin
Yes, agreed.  Looking back, I realize that I even guessed it in the original post.  Probably should have checked the ground before posting.  However, I always learn more by involving the good folks on the forum and greatly appreciate the assistance.  Thanks all!
And the winner was.......RT
Glad you got it sorted mate it is so frustrating.
RT wrote:And the winner was.......RT
The voice of wisdom and experience.  Smile
Good that it was a simple fix.
Onya RT Very Happy
Ha, as most know I'm a jubbo with this thing but it just sounded like something that happened to me.
My exuberant response is meant only as a self satisfying gesture, not to take anything away from the other
very legit solutions.
Made an old man happy for a minute (grandkids are here for holidays so it was just a short happy)
I've had that twice lately now the key is getting stick so I'm starting at the ignition switch!
Complete electrical failure--odd experience but working now; would still like input Ir-log1188....May contain nuts!Complete electrical failure--odd experience but working now; would still like input Ir-log11
K75RTP - 1994
good onya bob ...!!
cheers Justin ...good to hear you got a fix
Bob, for a moment I thought you said that you were a dubbo......we will have to educate our brothers from the north of the equator about that. Razz
As soon as it warms up I will be in Dubbo Stanley.
Thread back to Justin and his success.
KJustin
KJustin
Another interesting development.  Had some similar power failure after tightening the earth on the gearbox.  I jiggled the negative terminal on the battery and that solved the problem.  So apparently the battery is defective also (connection on the negative terminal is screwed down tight).  The battery has two sets of terminals, so I'll see if the other side is any better.  Going to be 2 weeks until I can do that since I'm going out of town shortly.
My problems also included an ever loosening negative connector on my battery, same symptoms happened if I hit a speed bump or driveway lip, dead in the water. I eventually put those star washers under the battery terminal screws and have had no problems since then.
It was the only time I ever felt like a guru, surrounded by youngsters (who pushed me into the carpark at Maccas), sidecovers off, ecu plug out, tray out, multi meter on, tighten tighten, back together, turn on, puff of smoke and away. "Who was that masked Mekhanic" I heard them say.
brilliant bob !!!  wow ....would have loved to have seen that in real life
your just too cool !
besides got to set an  example to those young whippersnappers I recon ....could  be, they actually didn't (...and never will), have a clue as to what you did and why ..
cheers from up here
Justin ...just a heads up
many of us have upgraded that dreaded earthing cable to something quite a bit more substantial
along with meatier lugs that connect to the battery and gearbox earth point ....some have even taken an auxiliary earth cable ( negative )  to the under tank earthing point ....(don't forget  that brown is the euro equivalent of earth or negative )
