1Back to top Go down   Lower first gear Empty Lower first gear Fri Jun 05, 2015 8:26 am
floyd
floyd
Any gurus out there know...?
Out of the plethora of gearboxes BMW have made....will any of them offer a lower first gear that will go into a K100 gearbox?
Would like to have more ability to craaaaawl along without working the dry clutch so much.
2Back to top Go down   Lower first gear Empty Re: Lower first gear Mon Jun 08, 2015 4:05 am
If you haven't used the 3.2:1 F/D from a K75, then that would be the 1st port of call.
3Back to top Go down   Lower first gear Empty Re: Lower first gear Mon Jun 08, 2015 4:38 am
floyd
floyd
K75cster wrote:If you haven't used the 3.2:1 F/D from a K75, then that would be the 1st port of call.
Cheers mate,
Soooo....This FD would have a lower rotational speed for a given engine rpm - correct?
Thanks for that one...obvious port of call as you say.
4Back to top Go down   Lower first gear Empty Re: Lower first gear Mon Jun 08, 2015 4:45 am
I have a feeling that all the ratios in the gearbox are all the same Floyd
the diff is the clue
unless you can do some magic in one of the similar r series boxes for first gear ....look for any monolever series for investigation is my guess ....twb and some others like the us based r series  mob might have some additional information ...swap gear sets for first ?
5Back to top Go down   Lower first gear Empty Re: Lower first gear Mon Jun 08, 2015 4:59 am
floyd
floyd
charlie99 wrote:I have a feeling that all the ratios in the gearbox are all the same Floyd
Thanks Charlie....Was hoping TWB would chime in with a part number hehe.
The 75 fd seems like a good idea...but will obviously effect the ratios across the board, rather than just 1st....that may be a good thing tho....my k loves to sit at 130-140kmh...just seems like thats where it wants to be....which gets me in trouble Wink
I was a postie for a while, and the training they gave me was some of the best motorcycle riding instruction ive ever had. Anyways....we had to craaaaaaawl along so slow. The test was something like we had to ride 10m in 30secs without putting our feet down. and had to do turns on the spot at full lock for a while. Was good fun...
Anyways, the K dont like to crawl Mad
6Back to top Go down   Lower first gear Empty Re: Lower first gear Mon Jun 08, 2015 5:03 am
um 40 to 240 in 5th gear ...nope they don't like to crawl
giggles
7Back to top Go down   Lower first gear Empty Re: Lower first gear Mon Jun 08, 2015 5:13 am
floyd
floyd
charlie99 wrote:um 40 to 240 in 5th gear ...nope they don't like to crawl
giggles
Thats flying, not crawling!
8Back to top Go down   Lower first gear Empty Re: Lower first gear Mon Jun 08, 2015 5:20 am
floyd
floyd
This graph compares the road speed of the RS, RT and 75 FD's on a K100 gearbox
The lines, from top to bottom, are RS, RT and 75
Lower first gear Ratio_10
9Back to top Go down   Lower first gear Empty Re: Lower first gear Mon Jun 08, 2015 7:08 am
If you do the calculation for 3000rpm as an example there's 3.5kph difference
Your K100RS
@3k rpm in 1st gear @4.50:1
FD ratio @2.81:1
Tyre circumfrence = 2m
Road speed = 28.6kph
Your K100 with K75 FD
FD ratio @3.20:1
Road speed = 25.1kph
 Lower first gear Austra12    Fuel:  95 Octane
10Back to top Go down   Lower first gear Empty Re: Lower first gear Mon Jun 08, 2015 10:13 am
floyd
floyd
Kaptain Holister wrote:If you do the calculation for 3000rpm as an example there's 3.5kph difference
Your K100RS
FD ratio @2.81:1
FD ratio @3.20:1
Thanks for some perspective Kapn Holister....
Having said that...when my current LT (swapped out from the knackered RS when I still had a spares cache...oh the days) packs it in, so to speak, I shall likely swap it out for a disc brake K75 unit....Time to investigate how many splines these units have....as Im also considering a driveshaft and swing arm lengthening and spline numbers are an obvious issue there.
fun stuff  Laughing
I wanna ride this beast to meet that Irish Eccentric mob we read so much about!  Lower first gear 502531
11Back to top Go down   Lower first gear Empty Re: Lower first gear Tue Jun 09, 2015 4:11 am
All the K75s had a 20 spline drive whether it was drum or disc rear brake.
