svlwolf
svlwolf
Bought these lights the 18w Led to mount to nose of upper fairing, however they weigh a little under 2lbs each, any suggestions? I am wondering if I may need to put a little metal reinforcement strip to help with the weight or just mount one in the center?
Mounting driving lights on Upper Fairing 85 K100RS 2x-4Inch-4-18W-1260LM-CREE-Led-Work-Light-Bar-Flood-Off-road-ATV-Boat-4WD
if you mount one in the centre ...it might interfere with the wheel - fender as you brake ...
go carefully
but I would reinforce the bolt through the fiberglass with plates either side
I took something similar off an 8v RS fairing I acquired some time ago. Obviously I have no idea how long they'd been on there but the fairing wasn't cracked. That said, if it had been me mounting them then yes, I'd have reinforced the mounting with metal plates.
And Charlie's right - do NOT try to mount one in the centre. Most of the time you'll be okay, but that first emergency stop will almost certainly smash the light into the mudguard.
Wolf, I'd certainly agree with Charlie and Dai, reinforcement of the mountings is highly recommended. Try and spread the contact point as broad as you can to save any undue stresses on body work.
I'm not sure how big those lights of yours are , but if you need extra room , try mounting a length of angle 25mm x 25mm ( 30mm if needed) under your nose cone to help move them out to a safer position . you will notice a couple of bikes in the recent Sydney Koffee trip with lights mounted under the Kone.
good luck with your endeavours.
Mounting driving lights on Upper Fairing 85 K100RS 10_x_110
I just bought 2 of these. They are good quality, very compact and light 188g (6.7oz) and a good price. I've not mounted them yet.
http://www.ebay.com/itm/1-2PCS-Cree-U2-LED-Motorcycle-Driving-Spot-Fog-Headlight-Waterproof-Lamp-30W-12V-/261697917754
Mounting driving lights on Upper Fairing 85 K100RS Poa217804
 Mounting driving lights on Upper Fairing 85 K100RS Austra12    Fuel:  95 Octane
PS you can get to the inside easily so the tube mounting can be ditched and just bolt straight thru onto a bracket
svlwolf
svlwolf
My plans to mount on cone, arrows indicate where I am mounting, plates shown with star where I will drill the hole and the plates will be cut to fit the inside and outside of the fairing
Mounting driving lights on Upper Fairing 85 K100RS 20150521Mounting driving lights on Upper Fairing 85 K100RS 20150522
Mounting driving lights on Upper Fairing 85 K100RS 20150523Mounting driving lights on Upper Fairing 85 K100RS 20150410Mounting driving lights on Upper Fairing 85 K100RS 20150411
1985 K100RS amidst customization bounce
Mounting driving lights on Upper Fairing 85 K100RS Usa-lo10
At 2lb each (that's 1.8kg) I think you'll be having problems in the future. I reckon the added load will stress the fairing mounting points not to mention the joints in the fairing. It's common enough for the fairing to break at those points at the fairing bracket. Would be a shame to damage that nice fairing.
I had a look at those lights on ebay and to me they look like work lights and at 18W not all that bright for the road at night. 1260lm is about what mine dim down too at ½ power and mine are only 180gm each.
If you mount each lamp independantly you will get more movement and more stress. GroverK above suggested a bar across teh two mounting points. GOOD IDEA. That will strengthen the mounting considerably by connecting the two together, reducing movement and vibration and spreading the load. I would use some aluminium extrusion about 35x12x3mm across the bottom between the two and a piece of the same on each side inside. The more holes you drill the weaker the mount will be. Two bolts each side would be sufficient imo.
Additionally, I would be reinforcing the fairing inside with fibreglassing and bed the pre-drilled inside brackets to that. Then an easy task when set to drill thru the fairing. Make sure the fibreglass sets slowly and cures for a few day to make sure its good and strong.
I would also see if it was possible to support them from the fairing bracket inside also. Just a thought. I'm not familiar with the inside of an RS fairing.
svlwolf
svlwolf
Kaptain, the more I think about it I just need to mount these on my 88 Isuzu Trooper and get some different ones for the bike that I dont have to do alot to mount them on the cone!!! Trying to get some that look militaryish !
These might be suitable
At 3000Lm they should be fairly bright. I don't think they're actually 125W. That's just marketing hype... 15W
There's no weight listed but they look similar to mine but without the cage so maybe around 200gm. I posted mine above.
You can take the bar mount off and bolt directly.
There are plenty of options out there, you just need to look around.
Mounting driving lights on Upper Fairing 85 K100RS MO00436-3
svlwolf
svlwolf
Kaptain, believe it or not they weigh a little over 1.5lbs , sooooooo gonna go with these
[url= http://www.ebay.com/itm/2x-New-Cree-LED-Work-Spot-Off-road-Lamp-Motorcycle-Car-Jeep-Boat-Fog-Light-10W-/251812159256?hash=item3aa12c9f1]http://www.ebay.com/itm/2x-New-Cree-LED-Work-Spot-Off-road-Lamp-Motorcycle-Car-Jeep-Boat-Fog-Light-10W-/251812159256?hash=item3aa12c9f1[/url]
Mounting driving lights on Upper Fairing 85 K100RS $_57
They look very compact.
Difficult to believe those others are 1½lb. Where did you read that. I couldn't see any weight specs anywhere.
k-rider
k-rider
I went with theSe
http://www.motorcykelgalleri.dk/fotoalbum/diverse-mc/30695-eagle_eye_
About 5gr. A piece rated 9watts
K-rider
