svlwolf
svlwolf
OK, I changed tires to shinko 244 series front and back, as I understand these tires can be used for either front or back, i assume that means that there is no rotation arrows on these tires whatsoever, anyway i noticed last night that the right side brake disc was against the fork, i took the allen bolt out of the axle and it moved out away from fork, Now mind you I just put the front tire on and had to DRIVE the axle in, SOOOO this morning I starting DRIVING the axle out with a socket and behold I notice on the right side the bearing has come out and stuck on the axle, anyway got that off and the spacers etc and straightened the lips of the spacer cups , i have taken 600 grit wet dry sandpaper to the end of the axle as i saw some nicks on it and smoothed it up, i cannot get the axle thru the bearings at all, matter of fact i would have to drive the axle in to get them on, i know its close tolerance but damn not that much..
So I am assuming something was not lined up when i installed and frigged the bearings on both sides, have both of them out and about to go get 2 new ones, any thoughts on this? cheers Do the spacer cups and end of axle look ok to you guys????
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 20150511
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 20150512
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 20150513
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 20150514
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 20150515
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 20150516
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 20150517
Svlwof - sounds like you are having something of a saga.
Most tyres have a direction of rotation on them - even if they can be used for front or rear. If you have ABS brakes, getting the wheel back on the right way round is easy - the toothed ABS sensor wheel is on the right hand side (just need to make sure the tyre is mounted correctly for the correct rotation)
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed Img_7614
With the wheel correctly installed, you will have a 3-4mm gap between the brake discs and the forks on both sides. Are you sure that you have put the spacers back correctly?
The axle is removed by slackening the two clamp bolts on the forks (two on each fork) and removing the allen screw from the left hand end of the axle spindle (I assume that you slackened these off). The axle should then slide out smoothly to the right hand side (if it wasn't lightly greased when installed, it can be quite stiff to move) using a tommy bar or some such passed through the hole at the right hand end of the axle spindle to allow the axle to be pulled out with a twistlng motion.
With the axle removed, two spacers will drop free - the larger of the two must be re-installed on the left side of the wheel and the smaller on the right. The wheel bearings are a press fit in the wheel hub and should not come out at all.
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed Img_7616  DAMNIT ALWAYS SOMETHING!!!!!Little Help needed Img_7615
Right hand side (thin spacer)                                                     Left hand side (fat spacer)
The difficulty you are having getting the axle spindle out or in again suggests that you may have bent the spindle or maybe that your forks are not correctly aligned. It should not be that tight a fit.
Have you tried putting the axle spindle thought the wheel hub with it off the bike? (i.e. not going through the forks). This would give an idea if the spindle is bent or not. If it slides though easily, then I would look at your fork alignment. If it doesn't, then that suggests damage to the spindle.
Ordinarily, getting the wheel back on is pretty easy. Get wheel between forks and brake callipers positioned on the brake discs. The axle spindle slides in from the right hand side, through the right fork, through the thin spacer, through the wheel hub, through the fat spacer and through the left hand fork and is then secured with the allen screw (to the correct torque). Pump the forks a few time to align the forks and then tighten the clamp bolts to the correct torque. It is usually to have to lift the wheel slightly to get the spindle through the fat spacer and left fork.
Good luck!
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed Uk-log10 DAMNIT ALWAYS SOMETHING!!!!!Little Help needed Sco-lo15
                              Paul  DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 905546712
svlwolf
svlwolf
Born Again Eccentric wrote:Svlwof - sounds like you are having something of a saga.
Most tyres have a direction of rotation on them - even if they can be used for front or rear. If you have ABS brakes, getting the wheel back on the right way round is easy - the toothed ABS sensor wheel is on the right hand side (just need to make sure the tyre is mounted correctly for the correct rotation) Svlwolf here, nowhere on these tires is an arrow like the original tires, they are knobby tires, i am absless, just good ole disc
With the wheel correctly installed, you will have a 3-4mm gap between the brake discs and the forks on both sides. Are you sure that you have put the spacers back correctly? Wolf here, yes I put the spacers on the right sides, BUT a possiblilty
The axle is removed by slackening the two clamp bolts on the forks (two on each fork) and removing the allen screw from the left hand end of the axle spindle (I assume that you slackened these off). The axle should then slide out smoothly to the right hand side (if it wasn't lightly greased when installed, it can be quite stiff to move) using a tommy bar or some such passed through the hole at the right hand end of the axle spindle to allow the axle to be pulled out with a twistlng motion. Svlwolf here, yes no problems originally when i removed it to replace the tires
With the axle removed, two spacers will drop free - the larger of the two must be re-installed on the left side of the wheel and the smaller on the right. The wheel bearings are a press fit in the wheel hub and should not come out at all. Svlwolf here, yes large on left and small on right , yes i know they should be press fit
The difficulty you are having getting the axle spindle out or in again suggests that you may have bent the spindle or maybe that your forks are not correctly aligned. It should not be that tight a fit. Svlwolf here, yes i did notice that the fork on the right side was sitting a little lower than the left side, so possible fork alignment the first time
Have you tried putting the axle spindle thought the wheel hub with it off the bike? (i.e. not going through the forks). This would give an idea if the spindle is bent or not. If it slides though easily, then I would look at your fork alignment. If it doesn't, then that suggests damage to the spindle. Svlwolf here, doesnt slide through either bearing at all, alll the other spacers etc go on just fine
Good luck!
Sorry - not trying to tell you the obvious, just trying to work out what's gone wrong.
The tyre rotation thing is a bit of a red herring (does that translate globally?) - there is no way that simply fitting the right sizes tyres could affect the axle spindle - even if they were put on with the rotation in the wrong direction (that just affects road handling performance). If you have gone for knobbly tyres - then it is quite likely that it really doesn't matter which way they go on as the tread is pretty uniform.
Bit concerned by your statements:
"Svlwolf here, yes no problems originally when i removed it to replace the tires"
and
"I just put the front tire on and had to DRIVE the axle in, SOOOO this morning I starting DRIVING the axle out with a socket
This sounds like you have had some misalignment, but have forced the spindle in, causing it to bind with the wheel bearing - probably damaging both the bearings and the spindle. Bugger! You may need new bearings (not expensive, but not a simple job to fit (BMW talks of heating up the wheel to get the new bearings in - tyre off job!!)) and maybe a new spindle too.
svlwolf
svlwolf
Born Again Eccentric wrote:Sorry - not trying to tell you the obvious, just trying to work out what's gone wrong.
Wolf here, No worry at all about the obvious, just trying to work thru it myself
The tyre rotation thing is a bit of a red herring (does that translate globally?) - there is no way that simply fitting the right sizes tyres could affect the axle spindle - even if they were put on with the rotation in the wrong direction (that just affects road handling performance). If you have gone for knobbly tyres - then it is quite likely that it really doesn't matter which way they go on as the tread is pretty uniform. Wolf here, my thoughts exactly!
and
This sounds like you have had some misalignment, but have forced the spindle in, causing it to bind with the wheel bearing - probably damaging both the bearings and the spindle. Bugger! You may need new bearings (not expensive, but not a simple job to fit (BMW talks of heating up the wheel to get the new bearings in - tyre off job!!)) and maybe a new spindle too. Svlwolf here, I just put the spindle on a straight edge at different locations all the way around the spindle, no signs at all of being warped or bent, however my thinking is about the bearings and am about to go get 2 to see if i may fix the problem!!
Trust me your input is very much appreciated  cheers
Be aware that it is a distance tube between the two bearings, it can have been malformed as it is rather soft.
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed Distan10
svlwolf
svlwolf
Yep the only thing i can see was one of the little "caps" on the end of the distance tube was a little bent, so i had read on here somewhere just to straighten it, and BTW just took the axel up to a guy at an auto parts house that works on bikes as well and he confirmed he saw nothing about the axle that would be the issue.. And looking up the fag and skf#'s didnt help him with Oreilly's , anyone have an alternate bearing that is available through auto parts houses in the USA?
That is standard bearings  SKF 6005 2RSH. (47 x 25 x 12 mm).
svlwolf
svlwolf
Ok, took some medium grit sand paper and worked the end of the axel and then 3M cloth and polished, bearings slide on and off with just enough resistance now!!!! gonna install and remount,,, carefully!!!!
That sounds like good news. The spindle is necessarily a very close fit in the bearings and it wouldn't take much distortion (caused by "driving out", possibly) to prevent it fitting at all. Glad to hear you were able to dress out the end of the spindle and get it to fit again.
Hope the rebuild goes smoothly.
svlwolf
svlwolf
WOW!!! WHAT A DAY
OK, bearings back in with distance tube between them, everything all lined up , shaft slides in and bumped through with palm of hand cheers, then on to put the allen bolt in the end of the axle, NNOOOOOOOO threads are buggered up right at end
SOOOOO find M10 tap, finally get threads cut into good threads , put washer on, screw Allen bolt in and torqued to spec,  santa brake calipers back on, fork pinch bolts in , tire spins like a merry go round
I have had a learning and fulfilling experience today! Really it sucked but I overcame :king:
It is all a learning experience. Beware of the  "safe place". If you ever put anything in this spot when stripping an item......you will not find it....for a very long time.
svlwolf
svlwolf
Oh yes it is very much a learning experience as I have never, ever worked on anything remotely close to a motorcycle Evil or Very Mad
There are no safe places DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 259495
1985 K100RS amidst customization bounce
DAMNIT ALWAYS SOMETHING!!!!!Little Help needed Usa-lo10
Aaahhh yes! the safe palce. Laughing  You scour the garage looking for that 10mm socket you just put down where you new you'd be able to get to it quickly while you're swapping out tools..... nope. Not there. You go upstairs thinking you left it on the kitchen bench when you made a cuppa. nope... not there. You check to see if its beer'o'clock yet but decide to make another cuppa Very Happy . You check your pockets again just in case you're going crazy. Nope. Back down stairs to have another look then scrounge thru a box of old sockets to find one that could fit. Back to the job and there it is sitting on the front of the bench where you left it. A few swear words at myself... DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 161205 .... now, what was I doing? Laughing
 DAMNIT ALWAYS SOMETHING!!!!!Little Help needed Austra12    Fuel:  95 Octane
Yes...safe places can also be expensive...I have many duplicate sets of nuts and bolts as a result of the "safe place".
Kaptain Holister wrote:Aaahhh yes! the safe palce. Laughing  You scour the garage looking for that 10mm socket you just put down where you new you'd be able to get to it quickly while you're swapping out tools..... nope. Not there. You go upstairs thinking you left it on the kitchen bench when you made a cuppa. nope... not there. You check to see if its beer'o'clock yet but decide to make another cuppa Very Happy . You check your pockets again just in case you're going crazy. Nope. Back down stairs to have another look then scrounge thru a box of old sockets to find one that could fit. Back to the job and there it is sitting on the front of the bench where you left it. A few swear words at myself... DAMNIT ALWAYS SOMETHING!!!!!Little Help needed 161205 .... now, what was I doing? Laughing
Not a problem when you have at least 6 socket sets of varying size range and quality, and all of them cover 10mm.   Very Happy
You can never have too many 10, 12, 13, and 14mm wrenches...
svlwolf
svlwolf
I also have an 88 Isuzu Trooper soooo YES I have Metric tools hid in places like some people hide guns to be able to get to anywhere in there home,,, its just my guns have a couple 10mm wrenches beside them!!!
