dark_gap
dark_gap
Good afternoon, I have a problem with the turn signals and horn of my bike, the buttons are really stiff and to turn on any of the turn signals, to stop it or to press the horn are really painful so...trying to repair this mess I have remove all the screws of the left handlebar switch, I have download the wiring diagrams from this helpful forum...but I discover that the little metallic 'dots' inside the high beam switch are really rusty, while I was cleaning it with some zero residue spray and low grit sandpaper, one of the cables has unsoldered and don't know where it goes...
So...can anybody post some photos of the inside of the switches to view which cable goes where...if you can upload of the both handlebar switches it will be very helpful cause tonight I will do the same with the righ side and I fear that the stuff will be the same...
Thanks a lot!!
This will have the info you need
Reparing Left Switch Block - Gaz80
 BMW K1/K100RS - Left Handlebar Switch Diagram/photo? Austra12    Fuel:  95 Octane
dark_gap
dark_gap
Kaptain Holister wrote:This will have the info you need
Wow! Thanks a lot, I promise I have spend about 20 minutes searching, but as far as I'm searching maybe the wrong words, this post did't appear.
Thanks a lot! I will try tomorrow to find where the cable was unsoldered.
Hi dark_gap,
KH has made the thread name a hyperlink, so you can just click on the line Reparing Left Switch Block - Gaz80  in his original post or your quote of his post, or this post.
(The search problem may also be that KH misspelled 'repairing' in this post.)  Wink   Link still works, though.
dark_gap
dark_gap
indian036 wrote:Hi dark_gap,
Thanks Bill, yes it works anyway. I found that there was a unsoldered cable that I have repair...but turn lights still flashing when they want after pressing the right or left button...I think that I must check all the wiring and also the flashing lights relay, well maybe all hehehe
I will keep you updated!
Thanks Again!
Cheers!
