1Back to top Go down   fuel injector - dead? Empty fuel injector - dead? Mon Apr 06, 2015 8:14 am
DaleRT
DaleRT
Hi all, Removed the fuel injectors to clean them on a RS K100 1986 due to stale fuel in the tank.
Measured the ohms on them, 3 of them read 16.plus, 1 read 7.7 This one is pictured with the dis-colouration.
fuel injector - dead? 101-9e10   fuel injector - dead? 101-2b11
Does the dis-colouration indicate anything?
Is the injector dead or professionally fixable? When activated the 'click' is not as clear as the other 3.
If its better to obtain another, any suggestions [has anyone tried others with success]?
The numbers on them are 552 on the connector, 0 280 150 210 on the body
Cheers  Dale
2Back to top Go down   fuel injector - dead? Empty Re: fuel injector - dead? Mon Apr 06, 2015 9:23 am
replace the low resistance one with the same type
im sure someone here has a spare around the place somewhere
id be guessing that there is some issues inside the injector itself
3Back to top Go down   fuel injector - dead? Empty Re: fuel injector - dead? Mon Apr 06, 2015 10:04 am
Looks like the steel body of the injector has left a rusty stain on the alloy.
4Back to top Go down   fuel injector - dead? Empty Re: fuel injector - dead? Mon Apr 06, 2015 10:13 am
It also turns out like that when you have a small leak at the o-ring.
5Back to top Go down   fuel injector - dead? Empty Re: fuel injector - dead? Mon Apr 06, 2015 12:09 pm
If you can't find a #210 and need to replace the set with a different type, as far as I can determine the 0280150705 is the closest match which is the injector for the 16v
What you're looking for is...
Single hole pintle
Impedance around 16ohm
Operating pressure of 2.5 bar (36psi)
Flow rate of around 160 to 165 cc/min at a test pressure of 3.0 bar (43psi)
 fuel injector - dead? Austra12    Fuel:  95 Octane
6Back to top Go down   fuel injector - dead? Empty Re: fuel injector - dead? Fri Apr 10, 2015 2:38 am
DaleRT
DaleRT
Thanks for the comments, its given me a direction to go. Dale
7Back to top Go down   fuel injector - dead? Empty fuel injector - dead? Fri Apr 10, 2015 8:32 pm
Hi Dale, I can send you up a couple of Blakeys refurbished ones to try out. Give me a PM, my daughter is coming tomorrow and lives at Warrimoo so I can get them up there by tomorrow night.
