1 Adding the Fuel level gauge and water temp gauge back... Mon Mar 30, 2015 10:21 pm
MikeisonTV
Having some trouble adding the fuel and water temp gauges back to the LT factory wiring harness.
The water temp gauge is working correctly. One down.
I get power to the red/white wire, the gauges I both illuminate green, but fuel gauge stays on E. I'm assuming there's away to test the float in the tank is functional?
Curious what these unused wires go to as well.
I know one set is a lighter. Is there a diagram or...
1st set) red/white stripe & brown=_______
2nd set) grey/white strip & brown=_______
3rd set) green/black stripe & brown=______
