1 Aftermarket Oxford grips wiring. Tue Mar 24, 2015 10:39 am
touchwoodsden
I have just fitted Oxford grips. I have located the wiring under the tank for the OEM grips and was planning to use that but it looks mighty thin! Is it okay with Oxford grips?
Does anyone know whether there is a fuse in that circuit or whether the OEM grips have their own fuse?
I have bought the ones with the “intelligent” control which allegedly tells you when the battery is draining because you’ve forgotten to turn them off but I am naturally sceptical as to how well it works. For that reason, I would prefer the supply to be switched.
If the intelligent control on the grips is reliable and works, I could go straight to the battery but really do like the idea of a switched supply
Am I worrying too much about the size of the cables for the heated grips which are in the loom?
Thanks all.
Thanks all.
