1Back to top Go down   LED Tail light Help Empty LED Tail light Help Tue Mar 31, 2015 5:50 pm
jhouse07
jhouse07
I have read many things but can not find a strait solution. Can i get some help how to wire these babies up.
I have replaced my big k1100rs tail light ears with this flush ones. I also have this relay http://www.drcproducts.com/elect/d45-69/index.html
The flasher relay on the bike just likes to buzz with nothing plugged in. Not sure but i also would like to mention i have no highlights or front turn signals plugged in either.
See pictures below for more detail.
Rear tail light harness.
LED Tail light Help CFA16A98-E769-4524-B502-8265B5388121
LED flasher cable.
LED Tail light Help E767FB03-9D9F-44A4-85EB-91B841BEE57C
old wires and harness
LED Tail light Help E52F68AA-049E-4B75-95D1-3071BE84D841
Flasher relay on k1100rs
LED Tail light Help 2CC7F07F-5A98-430A-B431-2DF99AD701F1
The Noise
2Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Tue Mar 31, 2015 6:51 pm
I'm pretty sure you can't use the LED relay with the OEM one. The LED relay assumes a 'standard' type indicator circuit which the OEM most certainly is not. Your best bet is four of these: http://www.ebay.co.uk/itm/2-Pairs-50W-6-LED-Indicator-Flash-Rate-Relay-Load-Resistor-Bulbs-Ballast-/380958588493?pt=LH_DefaultDomain_3&hash=item58b2e6be4d Note that they go in parallel with the LED indicator and not in series.
3Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Tue Mar 31, 2015 7:03 pm
jhouse07
jhouse07
Has you used these before. Are they proven to work. Thanks for the info also!
4Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Tue Mar 31, 2015 9:47 pm
Not on a brick but I have fitted them to a KZ1000 trike and a Guzzi 850T3. ANO too but I'm beat if I can remember what the other one was - a CX500 trike I think. All they do is present a load to the flasher relay that is the equivalent of an incandesant bulb.
5Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Wed Apr 01, 2015 3:25 am
Another metod......open the relay, inside you find a IC marked U2043B,
cut or disconnect leg #7 on this IC.
6Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Wed Apr 01, 2015 3:57 am
Bigsax
Bigsax
Hi Jhouse,
I like the look of those indicators!
Did you get them on Ebay?
LED Tail light Help Brick110
I stole this image, let me know if you want it back.
7Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Wed Apr 01, 2015 3:58 am
jhouse07
jhouse07
Bigsax wrote:Hi Jhouse,
Thanks. Here is where i found them. They happen to cover the old blinker holes perfect.
http://www.drcproducts.com/elect/d45-58-617/index.html
8Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Wed Apr 01, 2015 4:08 am
Bigsax
Bigsax
Thanks for the link.
I had trouble after I replace all my bulbs with led ones. I did as Inge suggests. I also ended up removing the relay/sensor as the warning light on the instruments does not recognise leds.
9Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Wed Apr 01, 2015 4:24 am
jhouse07
jhouse07
No problem. What relay/sensor are you talking about. where is that located
10Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Wed Apr 01, 2015 4:32 am
Bigsax
Bigsax
Been a little while since I did it. I will troll back through my posts and let you know.
11Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Wed Apr 01, 2015 4:34 am
good advice inge
might help solve this issue
"jhouse" that is some almighty relay action going on there ...
sounds like there is an almost open circuit, as the flasher relay is not opening far enough (due to near zero heat effect of load through the relay mechanism )
hope you get it solved
good luck
12Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Wed Apr 01, 2015 5:02 am
Bigsax
Bigsax
Jhouse,
this is the link to my led problems.
https://www.k100-forum.com/t7518-bake-warning-light
I don't think I had quite your problems though.
13Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Thu Apr 02, 2015 11:11 pm
jhouse07
jhouse07
Inge K. wrote:Another metod......open the relay, inside you find a IC marked U2043B,
This worked great. and saved me money
1996 k1100rs
14Back to top Go down   LED Tail light Help Empty Re: LED Tail light Help Fri Apr 03, 2015 2:48 am
win !!!
good to hear
