1 Bulb Monitoring Unit doesn't like LED in the instrument cluster Tue Mar 03, 2015 4:52 am
elukros
Hi,
After an upgrade of the instrument cluster with LED, I noticed something weird with the warning light.
Turning on the ingnition key and the kill swith off (ready to start) gives a steady warning light. Applying the front and rear brakes makes this light go out. So far so good, this is normal behaviour.
After that when I apply the front or the rear brakes, the warning light briefly lights up just at the moment the brake switch is closed. The warning light also briefly lights up when the brakes are released, just at the moment the brake switch is opened.
Can someone explain this phenomenom.
Luk
Luk
