1Back to top Go down   Alternator mounting Empty Alternator mounting Wed Mar 31, 2010 4:56 pm
Rickmeister
Rickmeister
Does anyone out there in K-Land know if there is supposed to be a ½mm thick washer between the mating surfaces of the alternator and the engine, as well as under the head of the bolt?.
For some inexplicable reason I put the washer between the mating surfaces when I replaced the alternator the other day.
2Back to top Go down   Alternator mounting Empty Re: Alternator mounting Wed Mar 31, 2010 6:18 pm
Here is the proper way to install the alternator drive:
Alternator mounting Altern10
Alternator mounting Frog15Alternator mounting Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   Alternator mounting Empty Re: Alternator mounting Thu Apr 01, 2010 7:10 pm
Hi Rick,
We have all done something equally inexplicable mine was doing incredibly good terminations on a big multi-core cable plug prior to pushing it through the hole in a firewall which was only just big enough for the cable alone, GRRR have to take off the plug and redo it AFTER pushing the cable through the hole. If I took a guess I doubt it will cause a problem if the washer is only 1/2 a mm thick.
4Back to top Go down   Alternator mounting Empty Re: Alternator mounting Thu Apr 01, 2010 9:34 pm
Rickmeister
Rickmeister
Thanks! I think the reason I did it was I saw washer marks on the mating surface of the alternator. I've since removed it again...luckily as one of the cush drive rubbers was all skew-if. I silasticed the rubbers onto the base of the cush drive houseing and lubed the edges so that it would slide in easily into the three vanes. I'm now certain that it is fitted correctly.
5Back to top Go down   Alternator mounting Empty Re: Alternator mounting Thu Apr 01, 2010 11:06 pm
Hi Rick,
That lubing the rubber bits is a good idea and well worth mentioning, as it helps the alternator slide into place without getting the bits out of place during the reassembly.
