1Back to top Go down   K75 Exhaust Mounting Empty K75 Exhaust Mounting Sat Aug 05, 2017 2:26 pm
The rubber metal hanger bracket has decided it is no longer up to the task. The point where the rubber joins the  metal has delaminated. Before I order a new one I thought I would have a go at either try to reglue the existing rubber or replace the rubber entirely with some form of silicone.  Inge has also pointed out that care needs to be taken if I order a new one as there are two types one for panniers and one for without. I have panniers. So guys any suggestions as to a repair or rebuild.
2Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sat Aug 05, 2017 9:38 pm
Can you drill the bracket to allow the front and back metal pieces to be screwed or pop riveted together?
3Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sat Aug 05, 2017 9:58 pm
I'd just get a new one. They're not too expensive. About $30 in the US.
4Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sat Aug 05, 2017 10:56 pm
I ended up siliconing it together and I am going to drill and tap a bolt through it with an over size hole on the bolt head side. I'll put a flat washer under head and Loctite the bolt in place or a locknut allowing for it to move slightly. A $30.00 part in the US equates to about $50.00 plus Au. I am going to phone the local non OEM parts dealer wrecker and see what his price is. I might also try the OEM dealer but they are unlikely to have one and if not it could take anywhere from 2 to 8 weeks. It takes 24 hours for the silicone to cure.
Thanks for the help regards Martin.
5Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sat Aug 05, 2017 11:56 pm
Some Aussie here probably has an extra one I''d be willing to bet.
6Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sun Aug 06, 2017 12:16 am
I've got a mate who has 3.5 K75's and one K100 all being worked on. I could ask him but I don't like bothering him. In the past he has loaned me parts while I am waiting for bits. He has a tendency not to sell anything. I might change my mind when I get the prices tomorrow.
7Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sun Aug 06, 2017 6:13 pm
If you need to change it, and only w/o z-frame versions is available....
you can always grind off a few millimeters on the spigots.
But plug and play is always easiest.......
8Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sun Aug 06, 2017 6:33 pm
Inge:
What's the difference between them?  Do the luggage ones have longer spacers on them?
9Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sun Aug 06, 2017 6:45 pm
First price in I just rang the local OEM dealer in Bris, $124.35 AU ex Germany. I was going to ring the local BM wrecker but I don't think my heart could take the strain. I going to ring the local Hospital and see what I can get for a kidney. Mate has offered to lend me one so I can order one from overseas probably cheaper than the local BM wrecker.
10Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sun Aug 06, 2017 8:04 pm
duck wrote:Inge:
Other way around....as the Z-frames is mounted between the footrest bridge
and the ekshaust mount....the spigots on the version which is used together
with the Z-frames is so much shorter as the space the Z-frames occupies.
11Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sun Aug 06, 2017 10:22 pm
Duck after seeing what you reckon the US price is, I thought maybe OEM dealer had stuffed up the price. So I rang a dealer up north and was very careful about describing it. Part numbers I quoted are superseded so I gave him the item number from the parts fiche. I got quoted 4-6 weeks ex Germany $140.00. Same part from Motobins UK $40.29 which includes freight. So I will be ordering from the UK tonight, in the meantime I glued it and ran a bolt through it.
12Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Sun Aug 06, 2017 10:56 pm
MartinW wrote:I got quoted 4-6 weeks ex Germany $140.00.
YIKES!
13Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Mon Aug 07, 2017 2:10 am
Welcome to our world Duck!
14Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Mon Aug 07, 2017 3:19 am
possibly worth a call to  Graemejays
he may just have something
are we sure that the hanger is different to the k100 version ?
worth a call at least ?
http://kmodelbeamerbits.com.au/bmwk-seriesshop.html#!/K75-Exhausts/c/18301030/offset=0&sort=normal
15Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Mon Aug 07, 2017 4:14 am
Martin,
I found one.  Whack a couple of those numbers off the end of the OEM price and that should cover postage.  Unless you would like to collect.
Dave.
16Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Mon Aug 07, 2017 4:55 am
Thanks Dave I've got a brand new one coming from the UK courtesy of Motobins, at a more reasonable $40.00 including freight. I tried the BM shop a few times no answer so I gave up. So I will not have to sell any body parts. Apparently there used to be two types of hangers one for with panniers and one for without. The only difference was the length of the lugs the 6mm bolts go through longer for ones with panniers. I've run a 6mm bolt through the split one as a temporary measure.
Regards Martin
17Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Mon Aug 07, 2017 4:58 am
charlie99 wrote:are we sure that the hanger is different to the k100 version ?
Same parts (18211454981 and 82) are used on K100s.
I think the 82 version is for use with the luggage Z racks,
18Back to top Go down   K75 Exhaust Mounting Empty Re: K75 Exhaust Mounting Mon Aug 07, 2017 5:12 am
Duck spot on the 82 is for Z brackets and can be cut down for non pannier mounting.
