1Back to top Go down   Spline lube on K100 with mk1 ABS? Empty Spline lube on K100 with mk1 ABS? Mon Feb 16, 2015 5:08 pm
Nigel T
Nigel T
Hi everyone,
I have recently bought a 1989 K100RS SE, the one with the first generation ABS, which is all a bit new to me on a motorbike...
Following the good advice I have started to do a spline lube, the wheel and bevel are out and I am asking for your guidance before going to the next stage.  I understand that I can pull the shaft, grease and replace with the swing arm still in place. I have watched Chris Harris's brilliant videos several times but they do not show ABS bikes. Mindful of the ABS and all it's plumbing, can I remove the gearbox bolts, replace with the slider bolts, unbolt from the frame and simply pull the whole box/swinging arm back just enough to grease the input splines?
I know the battery will need to come out, undo the starter and remove the alternator cover.  Any other advice would be appreciated.
Many thanks!
Regards
Nigel
Currently resident in the garage:
1989 BMW K100 RS SE
2 x 1982 Honda CX500B
Nigel T
Nigel T
Many thanks! Full knife and fork job it is then...
Regards
Nigel
1989 BMW K100 RS SE
