1Back to top Go down   Clutch centreing tool. Empty Clutch centreing tool. Fri Feb 13, 2015 4:15 pm
gabriel
Hi forum members
I forgot to purchase a clutch centering tool.
Is there an alternative way to centre the clutch?
2Back to top Go down   Clutch centreing tool. Empty Re: Clutch centreing tool. Fri Feb 13, 2015 4:21 pm
Kyle10
Kyle10
1985 K100rt 0052183
1983 Honda VF750 007713
3Back to top Go down   Clutch centreing tool. Empty Re: Clutch centreing tool. Fri Feb 13, 2015 5:35 pm
gabriel
Thanks...I have another questio...
I have purchased new pressure plates. Should I replace the friction plate?don't know if the friction plate is " shaped" over time. I'm concerned my friction plate is not completely flat and won't make proper contact with the pressure plates..
4Back to top Go down   Clutch centreing tool. Empty Re: Clutch centreing tool. Fri Feb 13, 2015 6:28 pm
Kyle10
Kyle10
Oh yes. Your concern is valid.
Besides, when you've got 'er all unbuttoned it'd be a waste not to install a fresh one.
1985 K100rt 0052183
5Back to top Go down   Clutch centreing tool. Empty Re: Clutch centreing tool. Mon Feb 16, 2015 9:14 am
post #143, page 3 on My rennovation thread shows how I made a very handy alignment tool in minutes which worked perfectly.
Align everything before you nip it up and hey presto!
Clutch centreing tool. Ir-log1188....May contain nuts!Clutch centreing tool. Ir-log11
K75RTP - 1994
6Back to top Go down   Clutch centreing tool. Empty Re: Clutch centreing tool. Mon Feb 16, 2015 11:08 am
japuentes
japuentes
Hi there, I think that, unless you're planning to make a living repairing old bmw motorcycle clutches, your best bet is the "paper mate marker" solution, shown on CF's previous post.
The centering tool is required only to let the gearbox spline easily and safely mate with the friction plate during the gearbox mounting.
Once this has been done, the friction plate will self center the first time you play the clutch lever and thus opening the pressure plates.
Best regards
JAP
Clutch centreing tool. 2854237993 1988 K100RS SE/ABS
