1Back to top Go down   Handlebar Size... Empty Handlebar Size... Wed Feb 04, 2015 3:57 pm
bettyswolloks
bettyswolloks
Hey all, can I use 7/8th size bars on the K or do they have to 22mm?
http://ranfog.co.uk
2Back to top Go down   Handlebar Size... Empty Re: Handlebar Size... Wed Feb 04, 2015 6:35 pm
Snod Blatter
Snod Blatter
They have to be 22mm otherwise your switchgear won't fit Handlebar Size... 112350
3Back to top Go down   Handlebar Size... Empty Re: Handlebar Size... Wed Feb 04, 2015 7:40 pm
You can use 7/8" if you sand off the chrome layer where the controls go.  Or you can enlarge the hole on the controls but then they will not fit 22mm bars again.  Better to do the former than the latter.
4Back to top Go down   Handlebar Size... Empty Re: Handlebar Size... Thu Feb 05, 2015 2:54 pm
bettyswolloks
bettyswolloks
Thanx for that Chaps, I thought as much on both your reply's, just needed confirmation from other peeps Smile
The journey continues........
http://ranfog.co.uk
5Back to top Go down   Handlebar Size... Empty Re: Handlebar Size... Sat Apr 25, 2015 5:02 am
bettyswolloks
bettyswolloks
Did a little of both. The bars where powder/plastic coated so I sanded them back to the wood, and got the dermal on the switchgear. The biggest issue was the throttle, had to mill out a couple of points to get a nice smooth action. The clutch side needed nothing but a spirited approach to fitting Wink
http://ranfog.co.uk
6Back to top Go down   Handlebar Size... Empty Re: Handlebar Size... Sat Apr 25, 2015 5:10 am
bettyswolloks wrote:Did a little of both. The bars where powder/plastic coated so I sanded them back to the wood, and got the dermal on the switchgear. The biggest issue was the throttle, had to mill out a couple of points to get a nice smooth action. The clutch side needed nothing but a spirited approach to fitting Wink
Wood? Wood the bike work now?
7Back to top Go down   Handlebar Size... Empty Re: Handlebar Size... Sat Apr 25, 2015 6:13 am
Mossy1200
Mossy1200
I have 7/8 ally clip-ons on mine and had to do a lot of bar sanding. Very time consuming.
