1Back to top Go down   "Float" on floating discs Empty "Float" on floating discs Sun Apr 26, 2015 4:43 am
Big G
Big G
Good morning
(Well it is a beaut here down South today anyway)
How much "float" should the front discs on my K100RS have? They seem to be rather rattly?
I don't know if the bobbins may be worn (80 000 km), and was considering the installation of a wave washer to tighten things up a bit.
BTW: my discs have plenty of meat left, just on 4 mm thick, which makes me think that the PO had replaced them (possibly with ones which have larger fixing cut-outs?)
I also have lost one of the bobbins on the left-hand disc- where do I shop for these?
1990 K100 RS (2015 - Current)
2005 R1150 GS - 35000 km (2007 - 2010)
1980 R80 GS - 28000 km (2005 - 2006)
2000 F650 GS - 102000 km (2000 - 2004)
1984 Suzuki Katana 750 - 72000 km (1984 - 1986)
1982 Suzuki DR500 - 48000 km (1982 - 1984)
2Back to top Go down   "Float" on floating discs Empty Re: "Float" on floating discs Sun Apr 26, 2015 6:12 am
Shouldn't get any rattle or movement you can feel. I found that there are quite a few brands of pads that rattle, I hear it more when I am turning tight when I go slowly. I bought some stainless bobbins from Motobins in UK.
I think that they should all have wave washers on them, I haven't seen any without them except for the non removable type like EBC.
3Back to top Go down   "Float" on floating discs Empty Rattling discs Sun Apr 26, 2015 7:23 am
Big G
Big G
Thanks Rick
Then I am definitely due for a set of bobbins.
A mate is ordering some stuff from Motorworks, I see they also stock the S/steel bobbins. Will get some with his order.
Cheers,
Big G
