1 Swing Arm Bearing OEM vs All Balls Wed Dec 31, 2014 2:31 am
Thought I would post these pics here rather than intrude on BooG's original post any more.
Here's a few pics showing the OEM swing arm bearing next to the All Balls replacement bearing.
All Balls state that every thing needed to replace the swing arm bearings in your K bike are in the box! Yeah right, what they don't say is you need to go to your local machine shop and have a spacer fabricated to make there bearings work. As All Balls did supply a bigger seal that was suppose to act as the spacer (sorry cant find that now) but that was totally useless.
So if you need to change the swing arm bearings, I recommend spending a bit more dosh for some quality not these cheap All Balls crap.
