1Back to top Go down   Removing bulb monitoring relay Empty Removing bulb monitoring relay Sun Dec 28, 2014 7:21 am
coopz
coopz
Hi Guys another one , if I remove the bulb monitoring relay will it make any difference to the running of the bike. The reason is I have cleaned all bulb contacts and brakes etc and still the dash warning light comes on. Ok hit brakes etc and it goes off but it still comes on when I go to start the bike every time. Regards Brian
1985 K100 RS
2Back to top Go down   Removing bulb monitoring relay Empty Re: Removing bulb monitoring relay Sun Dec 28, 2014 7:50 am
must...not...be...sarcastic...must...not...be...sarcastic. Very Happy
Unless I am missing something...the unit (relay) is working as designed.
Key in. ignition on. Dash warning light comes on. Tap the front and rear brake, light goes off. Go for a ride.
Finish your ride. Stop bike and turn off ignition.
Every time you restart the bike, the warning light comes on until you tap/use the brakes, then light goes off. If it doesn't, then you have a fault.
3Back to top Go down   Removing bulb monitoring relay Empty Re: Removing bulb monitoring relay Sun Dec 28, 2014 12:33 pm
A bit like the charge indicator light which is lit with the key on and goes off as required when the engine starts and revs rise. ChecK. All good.
You'd really love the early ABS check light which requires the bike move a few feet before engaging with a 'clink shink' (Firsttimer: what just broke and can I trust my brakes!?) then finally the bright red light goes off.
