1 temp switch and bulb monitoring units Thu Mar 18, 2021 12:30 pm
tinyspuds
In my box of k100 I have a fuse box/relay tray that I was going to use for spares after testing. All going well until I took out the temp and bulb monitoring units. Obviously many more pins than I was expecting and a non-DIN numbering schema.
I know the temp switch at least has a coil in it that I can test and I’ve read enough of Bert’s stuff to (maybe) design a testing regime that makes these components worth carrying. But, before I do, has someone already done this? I may still be locked down, but even so I don’t want to reinvent the wheel.
Also, does anyone know what the numbering schema used is called so that I can do more reading? Cheers, Stu
