1 where does this wire go? (barn find) Tue Mar 23, 2010 9:41 am
nodrtbike
Hello from this new member. I just bought a 1985 k100rt from a guy this weekend, got it pretty cheap I think, has new Michelin tires on it,extra Russel day long seat, (very ugly seat, may sell it?),small tour pack and side bags. According to the maintenance records it's had the speedo changed once, must have around 35k miles on it at least. I replaced the fuel pump and got it running, let it warm up a bit and changed the engine oil,tranny lube and final drive, flushed radiator, new anti-freeze.
I took it for a ride sunday and it runs really good,replaced the works racer shock on it with a koni that came with the bike, the guy who had it put the shorter works racer shock on it (may sale that shock also)and lowered the front forks a little. I raised the front forks back up to the original location.
These are the issues that I'm trying to fix currently... there's a violet/grey wire laying loose in front of the air filter box, it has 12 volts on it. The violet wire as well as a brown earth ground wire had the insulation chewed off from it (rodent nest). The brown wire is clipped onto a male blade on the backside of the rail that runs along the length of the engine, just to the left of the air box. But the violet/grey wire is laying loose in there and it has a female blade type clip on it, repaired the ends that were chewed up on both of those wires, reconnected the brown wire, but have not discovered where the violet/grey wire connects at. I've felt all around in the void in front of the air box to no avail. But I have yet to check up under the frame for a blade connector, do that this morning.
According to the clymer wiring diagram the violet/grey wire goes to the Vacuum switch, but i have not discovered where the vacuum switch is. I hope the connector for this wire is hiding up above where I have not looked.
OTHER ISSUES: the 2 fuel indicator lights and high temp do not "tell tale" at pre start ignition on. (bulbs to check yet)
the tachometer will only rev up to around 3200 rpm, then it just sticks there until the engine rpm drops below that rpm.
I've looked this forum over a little and found a lot of helpful information.
thanks, bob
thanks, bob
