Wire Plug, cable, wire identification please. Fri Jun 20, 2014 7:09 am
Englishstiv
![Englishstiv](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
Having trouble sussing this one out maybe someone can help? Three Q's for the price of One sorry folks!
I have an aftermarket headlight fitted which has a main and dip beam function with two individual aligned headlights (spotlight style)
Within the nacelle part of the light there are four wire cables two with plugs and two without.
The 1st plug is an Orange in colour with a green/black, a brown, a yellow and grey/black wires attached.
The 2nd is a Green in colour with green/black, brown, black and grey/black wires attached.
The 3rd wire is a single black wire that has been tucked in with no connector attached.
The 4th set of wires are brown and black and are if I am correct (and thank you Inge K for this info) for the ABS switch.
All wires come from under the tank between the fork stanchions along the main loom.
I am also trying to fit a permanent live riding/parking light that works in conjunction with the tail light that comes on with the switch in position 1 also ...any ideas will one of these wires be one ?
I also have the permanent red triangle alight in the dash will this go out when the ABS has travelled the distance or is it possibly a light fault?
Have looked at various wire diagrams and cannot fathom these out.
Any help much appreciated.
