Number of posts : 7967
When I had the problem with my K100LT I swapped the unit up under the headstock and it solved the problem. I never bothered getting it tested because BMW wanted €75 to do that and I bought one off Motorworks for much less. I actually don't know if it was the unit or the multi pin connection although I did clean them all up to no avail.
The K75 it was the unit under the seat and was the multi pin connection.
As KH has said, plug, injectors, HT and back from there. But in my mind its something that affects all 4 cylinders equally so my take is that its more likely to be further back in the system than an individual plug, lead or coil.
Having had a car go down here last week due to a fuel pressure sensor/regulator [would turn over and splutter but not run] I am wondering could there be an issue with that or a connection to it?
1971 Yamaha 125 YAS-1
