1Back to top Go down   Swing Arm Bearing OEM vs All Balls Empty Swing Arm Bearing OEM vs All Balls Wed Dec 31, 2014 2:31 am
Thought I would post these pics here rather than intrude on BooG's original post any more.
Here's a few pics showing the OEM swing arm bearing next to the All Balls replacement bearing.
All Balls state that every thing needed to replace the swing arm bearings in your K bike are in the box! Yeah right, what they don't say is you need to go to your local machine shop and have a spacer fabricated to make there bearings work. As All Balls did supply a bigger seal that was suppose to act as the spacer (sorry cant find that now) but that was totally useless.
So if you need to change the swing arm bearings, I recommend spending a bit more dosh for some quality not these cheap All Balls crap.
   Swing Arm Bearing OEM vs All Balls Fag_al10
Swing Arm Bearing OEM vs All Balls Fag_al11
Swing Arm Bearing OEM vs All Balls Fag_al12
They look like Paralever rear joint swingarm bearings to me.
This is the link Here sold to fit the K100 83 to 86
The outside diameter looks smaller or is that just camera tricks. The paralever bearings are smaller OD but I think ID is the same.
RicK G wrote:The outside diameter looks smaller or is that just camera tricks. The paralever bearings are smaller OD but I think ID is the same.
The dimensions are the same as the Fag, it's only the width that's different.
Its not what I thought it was then.
I am not a fan of those swingarm roller bearings, they don't take the load well when not rotating. You would be a lot better off with an angular contact ball race but they cost more.
