1Back to top Go down   Sidecar swingarm Empty Sidecar swingarm Sun Nov 09, 2014 6:33 pm
Rockman
I have this idea to use a K100 swingarm and final drive as a swingarm on a sidecar. This would allow me to use a K100 rear wheel on the S/C and would have a disc for a sidecar brake or handbrake. I'd remove the input pinion from the FD to reduce drag, and blank off the hole. I have a FD with stuffed splines, a spare rear wheel, and swingarms seem to be cheap.
Any reason why this wouldnt work?
2Back to top Go down   Sidecar swingarm Empty Re: Sidecar swingarm Sun Nov 09, 2014 6:43 pm
Hello Phil
I just sent a PM,
K100 RS
K100RS with 1100 motor Premier sidecar
K100 RT KRAUSER FAIRING
R1200GS
650 Vstrom
3Back to top Go down   Sidecar swingarm Empty Re: Sidecar swingarm Sun Nov 09, 2014 7:47 pm
Swinging arms are free at my place.
I think you are looking a a very bulky setup by the time the shockie is mounted. On the other hand it would be a heap cheaper than making a special hub for a K100 bolt pattern.
4Back to top Go down   Sidecar swingarm Empty Re: Sidecar swingarm Sun Nov 09, 2014 9:49 pm
Rockman
RicK G wrote:Swinging arms are free at my place.
I'd have to measure it up but maybe not much bulkier than the usual swingarm arrangement. And definitely cheaper since I have the final drive and wheel already. I'm hoping the R100 pivot pins are the same size as the K100 as I have a set of them as well. Time to get the tape measure out..
