rapt
rapt
I should start a build thread, or un-build. I am not using this as a daily commuter so I am going for more of a custom stripped down look.
Although I want to keep the option of taking passengers.
It is spring here and I will be riding most weekends, so if I take something apart it will be back together before the weekend.
Next winter I will be doing a full strip down, re-paint and re-condition of anything that needs it.
Here are some before shots.
I was told this is a ex USA police bike but I cant find any signs of anything that would have been mounted to it. It has about 70,000 miles on it. The body is in good condition, there is some rust on the frame and usuall corrosion on all the parts.
Rapt's - 1986 K100 - Cafe conversion Finished State_10
Rapt's - 1986 K100 - Cafe conversion Finished 32144710
Rapt's - 1986 K100 - Cafe conversion Finished 110
Ordered some parts, headlight, brackets, handle bars, mitrrors, indicators new tire. I was still deciding on what sort of speedo to buy but could not wait so I got stuck in and fitted the parts. I made a bracket so I could lower the speedo and mounted it to the existing mount on the clamps. All the fairing was removed and will be sold so someone else can restore a K100.
Rapt's - 1986 K100 - Cafe conversion Finished 20140811
Rapt's - 1986 K100 - Cafe conversion Finished 20141010
This is what it was looking like, I also had to touch up the missing paint on the engine to tidy it up a bit.
Rapt's - 1986 K100 - Cafe conversion Finished 210
More to follow but I am out of time.
I have installed a Acewell speedo, gear position indicator, relocated the key, tided up the rear shock, replaced the gear position sensor, modified the indicator relay, painted the forks, brakes, polished some bolts, cleaned up the front wheel.
Here is a preview of the front brake and forks after the restoration.
Rapt's - 1986 K100 - Cafe conversion Finished 310
You're doing a great job with the bike, I haven't seen that colour before, what is it?
that front looks nice ....good work
rapt wrote:I was told this is a ex USA police bike but I cant find any signs of anything that would have been mounted to it.
Post the last seven digits of the VIN and I'll tell you what BMWNA's Great Computer says it started life as...
rapt
rapt
Ok
The Digits are 0053852
rapt
rapt
Acewell Speedo install
I drilled in to the top fork clamp and used a self taping screw to mount the speedo.
Rapt's - 1986 K100 - Cafe conversion Finished 20141011
The wires were run in to the box that holds all the relays etc so I did not have to install a new box under the tank.
I also installed a Gear position indicator although I am only using it for the start enable function at the moment.
https://www.k100-forum.com/t8674-aftermarket-gear-indicator-neutral-indicator-board-3-circuit-fuse-block
For the wiring I followed one of the wiring diagrams on here. The only change I made was the alternator light. As there is an led in the acewell it was not drawing enough current to kick the alternator in to life so I installed a standard halogen 3W bulb behind the fuse holder so I can check it if I feel the need. Also the fuel gauge seems to be incompatible with the one on the Acewell, it shows empty apart from when the fuel light usually comes on then it shows full.
I made a simple bracket to hold the sensor using some Aluminium sheet, The Acelwell sensor was cut to make room for the bolt.
Rapt's - 1986 K100 - Cafe conversion Finished 20141012
It was then painted mounted along with a small Aluminium L bracket to hold the magnet.
Rapt's - 1986 K100 - Cafe conversion Finished Mount10
Mossy1200
Mossy1200
Nice work.
Your front wheel cleaned up well. Looks like fresh powdercoat job in photo.
rapt
rapt
The rear shock was looking a bit sad
Rapt's - 1986 K100 - Cafe conversion Finished 20141013
 It got a de-grease, the rust was sanded off, prepped for painting, a undercoat of etch primer and painted Saturn black (all this was done with out removing the spring, masking it was a pain!). Also while the rear caliper was off it got the same paint treatment. The aluminium on the shock was cleaned up with metal polish and steel wool.
Rapt's - 1986 K100 - Cafe conversion Finished 20141015
Now the front end was looking a bit sad so it got the following treatment over one week.
Every bolt I removed got cleaned up using 400 grit wet and dry to remove the 30 years of grime and pitted stainless. This was followed by 1000, 1200 wet and dry and finally a bit of metal polish on a rag (solvo). I found this was the fastest method and gave the best results.
Some before and after photos below.
Rapt's - 1986 K100 - Cafe conversion Finished 20141110
Rapt's - 1986 K100 - Cafe conversion Finished 20141111
More Bolts restored Before and after
Rapt's - 1986 K100 - Cafe conversion Finished Bolts10
Finally the forks, Brakes, disks were removed.
Before
Rapt's - 1986 K100 - Cafe conversion Finished 20141017
The forks were sanded back, 2x coats of primer, sanded with 1000 grit then 3 or 4 top coats of Saturn back with one more sand before the top coat. When the paint had hardened it was given a light rub down with polishing compound followed by a wax
Primer
Rapt's - 1986 K100 - Cafe conversion Finished 20141112
couple of top coats
Rapt's - 1986 K100 - Cafe conversion Finished 20141113
Finished product to follow
The inside of the disks were cleaned up with steel wool, de-greased, cleaned with meths and then primed and painted black, also the bolts were restored using the method above
Before
Rapt's - 1986 K100 - Cafe conversion Finished 20141114
Rapt's - 1986 K100 - Cafe conversion Finished 20141115
I am un-decided if I will paint the wheels, I think they look good black and Aluminium but the edges are rounded so I don't think I will get clean lines of silver and black. So for now they just got sanded with 1000 grit wet and dry to remove the corrosion and cleaned with steel wool and wd40.
The front calipers were cleaned up and painted. I removed the black plastic and that got a coat of black plastic restorer as did the brake lines.
I also sanded down the fork clamps with 320 grit, 400 grit, 1000 and then 12000 followed by some polish,
Sorry for the bad photo and no before photo
Rapt's - 1986 K100 - Cafe conversion Finished 20141117
So after it was all put back together I was pretty happy with the result.
Enlarge this image
Rapt's - 1986 K100 - Cafe conversion Finished 20141116
Mossy1200
Mossy1200
http://www.trademe.co.nz/motors/motorbikes/parts-for-sale/exhaust/auction-808164285.htm
I noticed this earlier. I have a muffler now but this pair would do the trick. Use the new rt side one un-rivet the end, revolve it 180 and invert the Yoshi label.
rapt
rapt
Mossy1200 wrote:http://www.trademe.co.nz/motors/motorbikes/parts-for-sale/exhaust/auction-808164285.htm
Nice one thanks, I have added to my watch list.
I want an exhaust that will be mounted flat as I am keeping the passenger pegs, do you think that this will do the job with out the stand hitting it  if I use Malcom's 4-1 combiner?
Mossy1200
Mossy1200
I want an exhaust that will be mounted flat as I am keeping the passenger pegs, do you think that this wi.ll do the job with out the stand hitting it  if I use Malcom's 4-1 combiner?
Yes he will do a straight end. Its a 3 bolt end but if you send the damaged front end to me ill take it 2 him and get him to add a flange to suit before he sends it 2 you. Shouldn't add much onto the cost.
Idd get a slight up curve before the flange after your passenger peg.
You may want shorten the end can a bit but that's very easy to do. I shortened mine 40mm.
Rapt's - 1986 K100 - Cafe conversion Finished Sany0518
12Back to top Go down   Rapt's - 1986 K100 - Cafe conversion Finished Empty Winter Tue Jun 16, 2015 7:39 am
rapt
rapt
So it is winter here, I have put a few thousand km on the bike over summer this is how the bike was looking at the end of Autumn
Rapt's - 1986 K100 - Cafe conversion Finished 20150510
Rapt's - 1986 K100 - Cafe conversion Finished 20150511
Now it is time to strip it down, replace any leaky seals & worn parts,  re-paint, clean up and recondition any old looking parts. As well as a new seat and some other mods. I will be selling all the old bodywork to restore another deserving K.
Oil Leaks.
1. Timing case. No gasket here? Just gasket goo?
Rapt's - 1986 K100 - Cafe conversion Finished 20150610
2. Not 100% sure with this one, crank case gasket?
Rapt's - 1986 K100 - Cafe conversion Finished 20150512
3. Oil pump, I am pretty sure it is all coming from the seep hole.
Looks like I need to replace the seals + Impella as I have the old version.
Rapt's - 1986 K100 - Cafe conversion Finished Oil_pu10
Rapt's - 1986 K100 - Cafe conversion Finished 20150611
no 2 ...likely to be the rubbers under the bolts ...they compress and go hard ...letting the rubber seal around the crank cover weep   but looks as if the oil is coming from the front of the engine ,,,rather than the crank cover
no 3    careful how you go on that ...you have the nut type ...rather than the bolt type ....the stud that the nut screws onto ...often break off at first undo force
hope that helps
Rapt's - 1986 K100 - Cafe conversion Finished Dreibo10
Works a charm where no gasket is specified, or anything like it: Fuji Bond, Three Bond, Honda Bond, Yama Bond, etc. Anything that is Type 1209 for flanges, though other 1200 types work as well.
rapt
rapt
Thanks for your help, I have sprayed the nut with some wd40 and will let is soak for a few days before removing.
The first thing I did was built a wooden stand, I have jacked the bike up from the sump and constructed the stand around the jack so the back and front wheels are off the ground. The jack was then removed and put back in the wife's car to keep hep happy.
Rapt's - 1986 K100 - Cafe conversion Finished 20150513
Every part that is removed will get painted or polished and the years of grease removed.
Some of the nut heads are rusty as the nickle plating has worn off or been sanded off so I will get these plated again, I priced it up and it is about $30.
Here are some before and afters.
The Aluminium is being cleaned up with copper plated wire brushes and WD40.
Rapt's - 1986 K100 - Cafe conversion Finished 20150612
My Box of parts is growing..
Rapt's - 1986 K100 - Cafe conversion Finished 20150613
Rear Diff,
I am unsure If I am going to paint the rear drive a similar colour to the Aluminium or leave it as it is.
The Black paint has protected the Aluminium so it is in good condition under that paint.
Rapt's - 1986 K100 - Cafe conversion Finished 20150616
Rapt's - 1986 K100 - Cafe conversion Finished 20150617
Rapt's - 1986 K100 - Cafe conversion Finished 20150614
Rapt's - 1986 K100 - Cafe conversion Finished 20150615
Rapt's - 1986 K100 - Cafe conversion Finished 20150618
My box of bits is now almost full. All the Nuts and bolts have been cleaned up bagged (in the kids lunch angry bird bags) and labelled ready for re-assembly.
Rapt's - 1986 K100 - Cafe conversion Finished 20150619
More to follow, but this is how it looks at the moment. I am going back to the garage.....
Rapt's - 1986 K100 - Cafe conversion Finished 20150620
sj2000
sj2000
Could you post the picture for the acewell speed sensor bracket in big format, I am going to use the same one for my bike.
rapt
rapt
sj2000 wrote:Could you post the picture for the acewell speed sensor bracket in big format, I am going to use the same one for my bike.
Hi, If you click on the images or click enlarge it will enlarge the images.
The bracket it just a small tab of Aluminium with two holes drilled in it. Then cut half of the sensor mount off so the bolt fits in place with out crushing the sensor.
The magnet mount is also the same, one hole for the magnet and one for the wheel bolt. make it long enough so you can bend it to be in the correct place to activate the sensor.
Mossy1200
Mossy1200
I did mine differently from everyone else.
I reversed the disk mount bolts and got stronger rare earth magnets that overcame the magnetising the bolts. I put the magnets in 2 layers of shrink sleeve to stop metal on magnet contact and set then in with non pick silicon. Used 2 magnets not one for more accuracy but might even change to 4.
I then made my bracket to suit the location.
rapt
rapt
Removed the stand, this is how it came off. Notice one of the bushes has come out, I am sure if I had used it a few more times it would have come out and the bike fallen over.
Rapt's - 1986 K100 - Cafe conversion Finished 20150621
At this stage I am not going to re-install the center stand so I have stripped back the side stand and mount, removed the rust and re-painted it.
Rapt's - 1986 K100 - Cafe conversion Finished 20150622
The carbs have been removed and cleaned up.
Moving on to the Tank. Although it looks nice in the green, I have decided to polish it.
I brought a three stage polishing kit. After doing a couple of trial runs I found that it needed allot more sanding to remove the pitting from when it has been sand blasted.
Rapt's - 1986 K100 - Cafe conversion Finished 20150623
After doing some research on polishing, all it needed was a sand down with 320 grit went and dry, followed by 400 grit. Then the three stages of polishing with grey, brown and white bars
Rapt's - 1986 K100 - Cafe conversion Finished 20150624
Rapt's - 1986 K100 - Cafe conversion Finished 20150625
Really happy with the result, it looks even better under natural light. The top is also a mirror finish you are just seeing the reflection of the ceiling. Worth the 8 hours of sanding and polishing and $70 worth of materials.
On to the engine.
Mossy1200
Mossy1200
Nice. I started doing mine then found a historic bogged dent in it so painted was the solution.
rapt
rapt
Thanks Mossy, I had my fingers crossed there were no dents.
To clean up the engine, I used paint stripper on painted parts (make sure you read the safety info, use in a well ventilated area), WD40 and a wire brush, Wire brush for the drill.
Rapt's - 1986 K100 - Cafe conversion Finished 20150711
Rapt's - 1986 K100 - Cafe conversion Finished 20150712
The engine covers will get a bit more of a touch up when they are removed.
Rapt's - 1986 K100 - Cafe conversion Finished 20150713
Back to the oil pump, I got the impeller off with out any issues. There is some minor wear marks in the shaft.
So from what I have been reading my options are
1. Clean up the shaft (if possible), buy the old type seal see if it bolts back up with out snapping.
Thoughts on this option?
2. Order a new shaft etc and seals, over $200 NZD for just the shaft.. Ouch
3. See if I can find a complete second hand pump off a newer bike and do the seals if they need it.
Rapt's - 1986 K100 - Cafe conversion Finished 20150714
Mossy1200
Mossy1200
Been trying to sell mine on trademe but no luck. Gotta find a 2 seat bike or the wife will want on the Agusta. Let me know if any of your mates down south are after one.
some very nice work going on there
keep at it ...it will look stunning when finished
24Back to top Go down   Rapt's - 1986 K100 - Cafe conversion Finished Empty update Thu Aug 13, 2015 5:31 am
rapt
rapt
Spring is on it's way here so I have been busy in the garage so I have plenty of time to ride this spring and summer.
The engine cover was black, I cleaned it off using paint stripper, and a steel brush mounted on a drill with some WD40, I don't like the wear mark form the fearing but there is not much I can do about it, unless I get the whole thing sand blasted.
Rapt's - 1986 K100 - Cafe conversion Finished 20150814
Rapt's - 1986 K100 - Cafe conversion Finished 20150815
Taped up the parts I don't want shiny, Hit it with 300 grit wet and dry followed by 600 grit then polished with with the buffing wheel using the brown, followed by white stick. Then painted using high temp paint
Rapt's - 1986 K100 - Cafe conversion Finished 20150816
Ahh that looks better.
The BMW logo on the other side of the engine got the same treatment.
I have fitted a new (second hand) oil pump as the old one has the old style impeller so it was less than half the price to get a second hand new style pump from a K1100LT one locally rather than buy a new shaft. The sellter said there was no leaks but I am prepared to buy a new seal for it if needed as it is easy enough to do.
Old pump
Rapt's - 1986 K100 - Cafe conversion Finished 20150627
Ordered new rubbers on the engine covers as some were cracked and cleaned up the bolts.
Rapt's - 1986 K100 - Cafe conversion Finished 20150810
 Rapt's - 1986 K100 - Cafe conversion Finished 20150811
The sump was up the sump and re-sprayed in high temperature spray paint.
I ended up using locktight red high temp gasket maker for the sump, engine covers and oil pump.
The surfaces were cleaned of the old silicone, de-greased and then I used paint thinners as the final wipe down before applying the gasket maker.
Rapt's - 1986 K100 - Cafe conversion Finished 20150813
I spent about 2 hours grinding the parts off the frame that I don't want there any more. Including the center stand lever. I hope I don't regret this part.....
Used a wire brush on a drill to remove the loose paint and rust. Treated the rust with rust kill, primed the metal and painted with Saturn black spray paint, a few coats followed by a light sand with 800 grit wet and dry and another couple of coats. This method is great for avoiding the orange peel look when using spray cans. Another tip is to run the can uner hot water to warm it up to about 30deg if you are in a cold climate like NZ winter.
before
Rapt's - 1986 K100 - Cafe conversion Finished 20150626
After
Rapt's - 1986 K100 - Cafe conversion Finished Frame10
Now it is back on my wooden stand and starting to be re-assembled.
Rapt's - 1986 K100 - Cafe conversion Finished 20150817
Rapt's - 1986 K100 - Cafe conversion Finished Carbs10
Things to do;
Re-assemble bike!
Cut rear frame
Make a base for the seat
Buy a Lithium battery
Buy a rear brake light
rapt
rapt
Ok, so the bike is done.
Some more progress photos below.
Engine and frame back together, Header pipes cut to fit the combiner on.
I found an old Inverter in a scrap metal bin and constructed a Aluminium case out of it to house the Lithium Ion battery.
Also New brake reservoir for the brake.
Rapt's - 1986 K100 - Cafe conversion Finished 20150812
Rapt's - 1986 K100 - Cafe conversion Finished 20150910
Rapt's - 1986 K100 - Cafe conversion Finished 20150911
Relocated the radiator overflow to the front using a metal drink bottle, drilled a hole in the cap for the hose and a tiny hole so it can breathe.
Rapt's - 1986 K100 - Cafe conversion Finished 22211
More to follow
That bike is coming along nicely! Good job.
I admit I'm not the best at housekeeping when it comes to keeping my bikes clean (I mainly ride them and do the prescribed maintenance) but they look pretty bloody good when they're all cleaned up fresh, almost like new!
27Back to top Go down   Rapt's - 1986 K100 - Cafe conversion Finished Empty Tail hoop Sat Oct 31, 2015 2:33 am
rapt
rapt
The tail hoop was a bit of a pain.
I could not get the same size tubing so I got slightly over side tubing bent up to match the frame.
I then cut out a slot for the led strip tail/indicator light that I got from fleabay.
Rapt's - 1986 K100 - Cafe conversion Finished 20150912
Rapt's - 1986 K100 - Cafe conversion Finished 20150913
Filled with epoxy to give the light something to sit against and inserted the tail/strip light.
Rapt's - 1986 K100 - Cafe conversion Finished 20150914
Testing
Rapt's - 1986 K100 - Cafe conversion Finished 20150915
Taped on for testing.
Rapt's - 1986 K100 - Cafe conversion Finished 20150917
Then I used parts of the smaller section of the old tail hoop to go inside the frame to act as supports and had a friend weld it on.
Works well and is very bright.
looking good ...unique even !
Needs to chase backward and forward to be a Xylon or a KITT. Wink
Looks good.
30Back to top Go down   Rapt's - 1986 K100 - Cafe conversion Finished Empty Exhaust Sun Nov 01, 2015 11:28 pm
rapt
rapt
Thanks for the comments.
For the exhaust I cut the headers just in front of the gear level and fitted the combiner.
The exhaust seemed a bit long so I cut it down and riveted the end back on. I figured if it was too loud I could always put the longer bit back on.
Rapt's - 1986 K100 - Cafe conversion Finished Exhaus10
I wanted the center of the back wheel visible, I had a spare BMW carbon logo as I used 2 on the tank so I stuck one on here.
The finish on the exhaust was rough so I sanded it down in one direction with some wet and dry to give it a similar look to the rest of the Aluminium on the bike
Rapt's - 1986 K100 - Cafe conversion Finished Exhaus12
I know you think this would be very loud but it is not bad at all. I have friends that have sports bikes that are much louder from factory.
The exhaust was a LeoVince with removable baffle, I opted to keep the baffle in there to provide a bit more back pressure and to keep the noise down a bit.
Next up Seat... Then finished photos.
31Back to top Go down   Rapt's - 1986 K100 - Cafe conversion Finished Empty Seat Thu Nov 12, 2015 1:25 am
rapt
rapt
Because the seat is so long and I wanted to keep it a 2 seater, I decided to make a 2 level seat with a cafe racer style hump on the back.
I got some Aluminium and shaped it to the frame. This stuff is terrible to work with when you don't have a sheet metal bender. I ended up cutting a slot in my work bench and fed the sheet through it while bending it with another bit of wood. Then cut it to shape.
Rapt's - 1986 K100 - Cafe conversion Finished 20150919
I ended up cutting the riser part that would have touched the tank off as I didn't want it to rub, figured that the foam from inside the seat would be fine.
Rapt's - 1986 K100 - Cafe conversion Finished 20150920
The Aluminium is sitting on small rubber stoppers that rest on the Frame and are riveted to the seat base.
To bolt the seat down I made an aluminium mount that would also hold the number plate at the back and drilled a hole to match with the cross support.
How to stop the bolts from spinning after the seat is covered..... Well I drilled a hole in a bit of scrap aluminium, used a dremel to get it to a similar shape and then smashed the head of the bolt through it. This was then riveted it on to the seat base so the bolt can't spin when the nut is done up.
Rapt's - 1986 K100 - Cafe conversion Finished 20150923
Rapt's - 1986 K100 - Cafe conversion Finished 20150921
Rapt's - 1986 K100 - Cafe conversion Finished 20150924
Finally got it off the wooden stand and back on it's wheels. Started it up and let it idle for a while and get to temperature, then fixed a leak in the one of the radiator hoses.
Rode it to the local place that does custom seats with a sketch of how I wanted it and he made it happen.
It was running really rough backfiring and not revving out, I also found a crack in the breather hose that connects back to the air box. After this was repaired with some rubber tape it was running fine.
Next up some finished shots.
32Back to top Go down   Rapt's - 1986 K100 - Cafe conversion Finished Empty Cafe racer finished Thu Nov 26, 2015 3:18 am
rapt
rapt
Finally got around to taking some finished photos.
Rapt's - 1986 K100 - Cafe conversion Finished Finish10
Rapt's - 1986 K100 - Cafe conversion Finished Finish11
Rapt's - 1986 K100 - Cafe conversion Finished Finish12
Rapt's - 1986 K100 - Cafe conversion Finished Finish13
Rapt's - 1986 K100 - Cafe conversion Finished Finish14
very shiney
good work ol mate
rapt
rapt
charlie99 wrote:very shiney
good work ol mate
Thanks, and for the advice earlier
Me likey!
Love the tank!
Nice job!
Chocolate
Chocolate
Well done!
Shining:-)
Sorry to mention it, but your petrol tank cap is fitted the wrong way round.
 The water drain is blocked in that position, unless you've modified the cap?
Well spotted Paul.
rapt
rapt
sidecar paul wrote:Sorry to mention it, but your petrol tank cap is fitted the wrong way round.
Thanks, I had better spin that around
andyldean
andyldean
Great job, the tank looks awesome and the work cleaning the engine was well worth while .
