1 K100RT Starting Issues Tue Mar 16, 2010 12:27 am
ToGGoT
Hi everyone! I posted a few questions on Flyingbrick, but havent managed to sort the problem, so i thought i'd try here instead!
Back story:
In September last year i bought a 1985 K100RT on Ebay as a non-runner with the intention of a quick fix and tidy as i went along. Sadly when i collected the bike i discovered it wasnt quite as good as the pictures made out (along with a semi rolling chassis came 5 boxes containing the rest of the bike...)
Over the winter i've TOTALLY rebuilt the bike as a naked K100, and after managing to unsieze the engine (stuck solid) i'm most of the way to getting it back on the road.
Now comes the problem. Between me and my stepdad we've managed to get the bike to start twice. The first time was a fluke with loads of easy start, and it ran for about 10 minutes. The second time was after 45 minutes of tweaking, and i have no idea what made it come to life.
Now, she absolutely does NOT want to play.
The engine turns and turns, and fires a bit, but doesnt ever really catch.
I have already done a LOT of troubleshooting, so bear with me!
It has:
New Plugs, New HT Leads, New fuel pump, new fuel hoses, new fuel filter, new oil, new oil filter.
The injectors have been ansu tested and cleaned, and are good.
I have replaced the fuel regulator, and am getting 2.8bar consistently.
All four plugs are wet after cranking.
Good spark at all four plugs.
The plugs ARE on the right coils.
We have tried with one new, and one known good battery.
I have checked the air, and water temp sensors, both read withing known good values. I have resistance checked the air flow meter, and it meets the results for a known good one.
The cam timing is correct, and the ignition timing is as close as i can get it without having the bike started.
*Breathes out*
The only concerns i have any idea about now are a) that the starter doesnt seem to crank very fast. It was stuck when i tried to test it to start with, so i dismantled it, and cleaned and unjammed the brushes, and re-assembled and it works well. I have never had a BMW before, so i dont know what the cranking speed is supposed to be.
b) If i take the lead off the starter, and turn the ignition on i get 12v at the feed for the starter. Without pressing the starter button. In my mind this is NOT right, but if i then touch the starter lead onto the contact, the relay clicks, and the voltage drops back to pretty much nothing.
Press the button, and the starter cranks, and the voltage jumps right back up again. Sick Relay?
Anyway, i really want to get using the bike ASAP, so any ideas you've got that help me narrow this down would be well appreciated!
Cheers!
ToGGoT
Back story:
It has:
*Breathes out*
Cheers!
ToGGoT
