1Back to top Go down   Wanted: clutch friction plates Empty Wanted: clutch friction plates Tue Sep 30, 2014 5:50 pm
gabriel
Hi everyone
I'm after a clutch friction plate..the one with the three pins..not certain if I have to replace the other friction plate as well.
I'm desperate to get my bike back on the road.
All suggestions will be appreciated.
I reside in melbourne australia.
Gabriel
2Back to top Go down   Wanted: clutch friction plates Empty Re: Wanted: clutch friction plates Tue Sep 30, 2014 6:16 pm
nino
Hi, Gabriel I ordered friction plate, set of bolts and O ring from www.motorworks.co.uk. Everything was fine, that parts I changed before 3 years and bike still run well.  As I understood forum members from Australia used to order from Motorworks.
Best regards
3Back to top Go down   Wanted: clutch friction plates Empty Wanted: clutch friction plates Tue Sep 30, 2014 7:01 pm
I just got a couple from Motorworks UK, washers, nuts and bolts as well for Rossko and I, took 5 days only, including a weekend. Mind you the Aussie dollar was .9350 when I ordered, they costed about $140 with postage.
4Back to top Go down   Wanted: clutch friction plates Empty Re: Wanted: clutch friction plates Tue Sep 30, 2014 7:42 pm
Search Motorworks for CLK51273.
Used part is 25gbp.
Not sure I have a spare one hanging round.
5Back to top Go down   Wanted: clutch friction plates Empty Re: Wanted: clutch friction plates Tue Sep 30, 2014 8:36 pm
Be made
Be made
NZ new $115.00 nzd here aftermarket mine goes good
6Back to top Go down   Wanted: clutch friction plates Empty Re: Wanted: clutch friction plates Tue Sep 30, 2014 9:38 pm
gabriel wrote:Hi everyone
Gabriel
From what you say about the 3 pins you want the steel pressure plate not what is commonly referred to as the friction plate.
Motobins have both steel plates and I would recommend getting new items as the older ones are often dished and only touch at the outer edge of the friction plate and slip.
I have 5 sets of steels here but all are dished and I had to machine a pressure plate to get a good one last time I needed one. As an economic proposition machining an old one is not worthwhile.
7Back to top Go down   Wanted: clutch friction plates Empty Re: Wanted: clutch friction plates Wed Oct 01, 2014 12:07 pm
Be made
Be made
Well spotted Rick . . ..lol. That's the case so I withdraw my earlier price estimate
8Back to top Go down   Wanted: clutch friction plates Empty Re: Wanted: clutch friction plates Wed Oct 01, 2014 7:18 pm
Be made
Be made
Thinking about this, if your pressure plate is needing replacement it is a fair guess that the friction plate will need to be replaced as well.
If me I would replace both as the job of getting the box off and on is a pain in the rear end to say the least and you need your bike to be ultra reliable
